It is currently Fri Apr 10, 2026 1:43 pm
Reply to topic  [ 4 posts ]
 PVT Arias Piston Specs.
Post PVT Arias Piston Specs.
Anyone know what the specs are for the run of the mill Arias piston from PVT. Looking for the compression height and didn't think to measure before I put them in. Stock bore. Trying to calculate CR so I can decide on head decking.
Sat Oct 22, 2016 1:46 am
Post Re: PVT Arias Piston Specs.
use silly-puddy, that's what we would use to check clearance.
Sat Oct 22, 2016 5:25 pm
Other than pulling the piston to measure center of wrist pin to top of piston, lets hope someone can help ya. I'm sure if you call Al he will help you out man!
Mon Oct 24, 2016 5:57 am
Al says CR with that combo should be slightly more than 10 to 1 if the heads and gasket are stock.
Mon Oct 24, 2016 9:52 pm
