It is currently Fri Apr 10, 2026 12:53 pm
Reply to topic  [ 10 posts ]
 Decked Heads vs Cylinder Pressure
Post Decked Heads vs Cylinder Pressure
Trying to find an example of what every .010" of decking equals in cylinder pressure. For example decking/removing 0.010" will increase cylinder pressure 6 psi. Anyone have any before and after pressures?
Tue Oct 25, 2016 2:56 am
Post Re: Decked Heads vs Cylinder Pressure
Too many variables to say what it will be. Briggs has a wide range of tolerances so it is not consistent. Some stock motors have 120 PSI of cranking compression, some have 130 PSI. It is a moot point.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Tue Oct 25, 2016 5:21 am
Even still the cylinder volume will be getting smaller. I'm not looking for the total pressure number just the amount of pressure that will be gained by every 0.010" taken off of the heads. If that makes sense? I'm trying to figure out how muck decking it will take to raise my personal cylinder pressure 35 psi.
Tue Oct 25, 2016 7:41 am
As he said lots of variables, but I would guess you are looking for about a .040 chop with a stock cam
Tue Oct 25, 2016 8:06 am
To add an example. I've got a cam and .025 chop and sit at 165
Tue Oct 25, 2016 8:09 am
Gauge variables will also apply.
Tue Oct 25, 2016 8:19 am
From my experience .045" chop stock cam cranking is about 175 ish.. .065 shop is about 195-200 ish
Bayou Surface Drive
337-351-0362
Tue Oct 25, 2016 8:27 am
Ok so if 0.045" produces 175 psi what was stock psi on that particular engine? 175 minus stock number divided by 4.5 would be the number I'm looking for? Any more clear?
Tue Oct 25, 2016 8:39 am
Or I guess you could say 195-175 diivided by 2 would be 10 psi per 0.010". Thanks everybody.
Tue Oct 25, 2016 8:45 am
It just depends on alot of factors. Good valve seal and ring seal to get good compression numbers.
Bayou Surface Drive
337-351-0362
Tue Oct 25, 2016 8:57 am
