It is currently Thu Apr 02, 2026 12:57 pm
Reply to topic  [ 2 posts ]
 Adjusted governed on 36pd now wants to rev on its own help
Post Adjusted governed on 36pd now wants to rev on its own help
I adjusted the governed on my 07 prodrive now my t wants to rev up on its own any help
Wed Nov 16, 2016 1:10 am
Post Re: Adjusted governed on 36pd now wants to rev on its own he
You adjusted too much, you need to dial it back some. I had an 07 briggs on mine before swapping to a Kawasaki. You need a stiffer spring that will allow you to adjust more. Prob is, they are like trying to find a needle in a haystack. So this is what I did. Take your governor spring off, should have several wound coils. I used some SS wire, but you can use a tie wrap also. Take about 4 coils of the spring and wire or tiewrap them together. Thus making the spring stiffer. Before I did this, mine would adjust past 4600, after stiffening the spring, I could spin to 5000+ with my then stage 2. So you need to adjust the govnor back so that the engine idles normal, then do as I did above.
Thu Nov 17, 2016 5:21 am
