It is currently Thu Apr 02, 2026 12:58 pm
[ 8 posts ] |
WI WATERFOWL
 Briggs Timing Key
Where is the best place to get a advanced timing key for a 20hp Briggs? eccarburetors sells them but they want more for shipping then they do the part. I had one from CartsPlus but sheared that one right after installing it so have been back to the stock timing key, and I don;t see them on CartsPlus website anymore.
| Tue Nov 15, 2016 5:01 pm |
Will
 Re: Briggs Timing Key
That's the problem, they're cheap but cost more to ship. You don't technically need it, just turn the flywheel and bolt it back down. You could go as far as painting a line and using a timing light but you can wing it also. If you sheared the first one, your flywheel wasn't tight enough.
_________________ Before the internet, the majority of the village idiots stayed in their villages.
| Wed Nov 16, 2016 8:13 am |
reharbert
Joined: Tue Mar 17, 2015 1:38 am Posts: 606 Location: Beaumont, Texas
Will nailed it. Your key is simply for indexing. It's not designed to hold the flywheel in place.
_________________ Uncle J - 17 x 48 w/GTR | Bayou Surface Drive heads | Voodoo exhaust | DIY Mikuni carb
| Wed Nov 16, 2016 4:23 pm |
50fps
| Wed Nov 16, 2016 5:43 pm |
WI WATERFOWL
lapping compound is the same as valve grinding compound correct? I just watched a video on how to lap the crankshaft and flywheel. Someone on here had mentioned that I should have done that when I said I found my advanced timing key I had just installed sheared......live and learn, I had no idea.
I just ordered a new advanced timing key from ECCarb today, don't want to mess with a timing light or trying to index myself without a key. I am going to do the lapping this time. Good project over the winder for me. Will run the stock key the rest of the season here.
Thanks guys!
| Wed Nov 16, 2016 9:31 pm |
cb5331
As noted above, if you sheared the key, it was because the flywheel wasn't torqued properly. The key is just for alignment, it doesn't hold the flywheel in place.
| Thu Nov 17, 2016 9:27 am |
WI WATERFOWL
Best way to stop the shaft from spinning when tightening the flywheel down? Put something in the ujoint or?
| Mon Nov 21, 2016 3:39 pm |
reharbert
Use an impact. Or hammer wrench!
| Mon Nov 21, 2016 4:25 pm |
[ 8 posts ] |
