It is currently Tue Mar 31, 2026 5:59 am
[ 8 posts ] |
lagunaduck
 35 gd blowing oil
I have a 35 hp gd that was running good 4weeks ago. Had a a week of good hunting and engine running fine. Today I went to run the engine and it won't start. Checked oil and had none on dipstick. Added 1 quart of oil. Will start after much cranking and will run for about 10 seconds. When it runs it blows a huge smoke screen and spits oil out the muffler and out the air filter. Any ideas?
| Sun Feb 05, 2017 6:06 pm |
Will C
 Re: 35 gd blowing oil
High possiblilty of a blown headgasket
| Sun Feb 05, 2017 7:17 pm |
flint87
I had a bad seal on a head cover gasket and had oil everywhere
| Sun Feb 05, 2017 7:36 pm |
RootSumn
Joined: Thu Jan 13, 2011 11:55 am Posts: 1126 Location: Hawthorne, Fl
I've had to replace my rear crank case gasket twice after 350 hours. It's a Briggs issue, not a GD problem.
_________________ 1654 Grizzly '13 35 GDSD
"You should be more concerned with watching football than making chit fall out the sky!!!" - My Wife
| Sun Feb 05, 2017 8:00 pm |
MaXXis85
| Mon Feb 06, 2017 7:30 am |
justooln2
Joined: Fri Dec 16, 2016 7:41 am Posts: 7 Location: Central Il 61526
You do a compression test yet?
Something else to try us a low pressure gauge on the dipstick tube, see if there's positive pressure.
| Tue Feb 07, 2017 9:27 am |
lagunaduck
Thanks for the tips. I am planning on doing a compression test this weekend. After further inspection, it's not blowing oil out the carb, but mostly the oil. Had somebody mention to me that the carb may be leaking gas into the crankcase causing the oil to thin. Planning on draining the oil and inspecting it. Thinking maybe a carb kit? The engine has 45 hours and the valves have not been adjusted. Don't know if this would have any impact on the oil blowing out the muffler.
| Tue Feb 07, 2017 7:21 pm |
lagunaduck
Sorry... out the muffler
| Tue Feb 07, 2017 7:22 pm |
[ 8 posts ] |
