It is currently Tue Mar 31, 2026 4:06 am
Reply to topic  [ 21 posts ]
 BEST MOD WITHOUT DOING MOTOR WORK
Post BEST MOD WITHOUT DOING MOTOR WORK
WHAT CAN I DO TO MOD MY 37 EFI GT WITHOUT DOING ALOT OF MOTOR WORK ?
PROGRAMMERS , EXHAUST ?
1754 UNCLE J 37EFI GTR stage 2 Delta ,
Thu Feb 09, 2017 1:52 pm
Post Re: BEST MOD WITHOUT DOING MOTOR WORK
Your best bang for your buck is Headwork. Sure an exhaust helps on the EFI moreso that the carb'ed, BUT a good set of heads will make sure your engine is running efficient, has more PSI, and better flowing ports!
Thu Feb 09, 2017 1:54 pm
thx you
Thu Feb 09, 2017 1:57 pm
Performance in a bottle = Synthetic oil and octane booster.
Thu Feb 09, 2017 1:59 pm
^ Fuck YES!
Thu Feb 09, 2017 2:07 pm
Avgas
Thu Feb 09, 2017 3:04 pm
Nitrous..... the only real Hp in a bottle :)
-Custom pool noodle
-stage 4 water wings
Thu Feb 09, 2017 5:42 pm
prop work---
Thu Feb 09, 2017 7:57 pm
YEA GONNA RUNN A BIG BLADE THIS WEEK TO SEE HOW IT DOES
Thu Feb 09, 2017 8:27 pm
SOUNDS GOOD
-Custom pool noodle
Thu Feb 09, 2017 9:51 pm
Fri Feb 10, 2017 6:16 am
-Custom pool noodle
Fri Feb 10, 2017 7:06 am
Exhaust and worked prop will be about the only things you can do before breaking into the motor.
Anyone have a dyno showing the added HP and torque with a stainless works exhaust, I've seen a sheet on a voodoo And I was wondering how other exhaust compare to the it.
Fri Feb 10, 2017 9:03 am
Last time I checked, the heads were on the outside of the block.
Fri Feb 10, 2017 9:16 am
Fri Feb 10, 2017 9:31 am
Cool. I thought they were.
Fri Feb 10, 2017 9:33 am
Sorry exhaust, prop work, and heads.
Fri Feb 10, 2017 9:50 am
Prop work is not an engine mod and is horribly unreliable.
Fri Feb 10, 2017 9:51 am
Agreed but it will get some extra performance out of the motor before it wears down.
Fri Feb 10, 2017 10:11 am
Fri Feb 10, 2017 1:17 pm
And then its worn out and you get to start over again. :lol: also, you usually sacrifice something to gain something else with props.
Fri Feb 10, 2017 1:23 pm
