MaXXis85
 Vanguard 35-36-37 stock cam specs
This was checked in a block for accuracy. Vanguard 35 camshaft Intake Open .050" 15* atdc Close .050" 39* abdc Icl 117* Lift .276" 204* duration at .050"
Exhaust Open .050" 26* bbdc Close .050" 8* BTDC Ecl 107* Lift .260" 198* duration at .050"
Lsa 112*
| Tue Feb 21, 2017 7:25 am |
Will C
 Re: Vanguard 35-36-37 stock cam specs
so briggs runs that little cam 5* retarded. I Learned somthin new today
| Tue Feb 21, 2017 8:23 am |
cb5331
Yes, briggs is retarded.
| Tue Feb 21, 2017 8:26 am |
Will C
I knew that was coming, and from you
| Tue Feb 21, 2017 8:28 am |
MaXXis85
Those center lines, low lift, low duration, and almost no overlap... Its amazing how well they run stock considering. No wander when you add a cam they make a HUGE jump in power all across the board.
| Tue Feb 21, 2017 8:31 am |
MaXXis85
| Tue Feb 21, 2017 8:32 am |
cb5331
Have you checked more than one cam? Seems like I remember Cody saying he'd seen the centerlines off by as much as 5* between two.
| Tue Feb 21, 2017 8:33 am |
MaXXis85
This is the only one I checked. The others have the typical lobe issues This is from a 400 hour PD with perfect spinning tappets and no scarring or worn lobes on the cam.
| Tue Feb 21, 2017 8:48 am |
cb5331
Cool! Good info!
| Tue Feb 21, 2017 8:55 am |
cb5331
| Tue Feb 21, 2017 10:49 am |
