Wood
Joined: Wed Jan 14, 2015 8:55 am Posts: 24 Location: SWLA
 Heads + gutted exhaust = blue flame?
I recently installed delta heads with a new gutted stock exhaust on my pro drive 36 on 18x54 sbx. Cranked it up last night at the house and noticed it spitting the occasional blue flame out the exhaust. Is this normal with a gutted exhaust? I removed all baffles and cut the perforated end off the outlet pipe inside the can and welded back up. I'm running a gator tail stock exhaust on a pro drive if that matters, but wouldn't think it does. Haven't had it on the water yet, hope to try it tomorrow. Seems to run fine other than the blue flames at night and occasional backfire. I'm guessing I should have left the perforated pipe on the outlet in place, just wanted to make sure flames weren't indicating something else going on. Stock motor needed some help with pushing loads in that heavy boat.
| Wed Feb 22, 2017 8:49 am |
JphIII
 Re: Heads + gutted exhaust = blue flame?
Was it in a dark or lit area, perfectly normal to see blue flames with AM exhaust and headwork at night. You'll see it just with a better flowing exhaust.
_________________ PD 1754 X Series and a PD 37EFI
| Wed Feb 22, 2017 9:03 am |
Wood
It was dark, I'll try to upload a video if I can get it to go through. Good to hear it should be normal though!
| Wed Feb 22, 2017 9:08 am |
Wood
https://youtu.be/cMhC-rj7d6QShould work, couldn't get it to upload through tapatalk. Sent from my SAMSUNG-SM-G891A using Tapatalk
| Wed Feb 22, 2017 9:23 am |
BayouBuster
Joined: Sat Jun 25, 2011 8:33 am Posts: 1352 Location: Genoa AR
Roll with it, they all do that.
Sent from my SAMSUNG-SM-G890A using Tapatalk
| Wed Feb 22, 2017 9:27 am |
cb5331
| Wed Feb 22, 2017 9:40 am |
Smoke
Joined: Fri Jan 23, 2009 1:27 pm Posts: 1095 Location: SW Michigan
Those are short you'll be fine.  I used to have 3-4" blue flames out my old duals constantly. Looks good at night!  The only problem is, you would be able to enjoy the show since there behind ya.
_________________ 1854 Prodigy Open HDR/Stage 3 mods Prodigy Boats Pro Staff BPS Swamp Staff Member Blackwater Marine LLC.
| Wed Feb 22, 2017 11:15 am |
MaXXis85
the holes are hitting!!!
| Wed Feb 22, 2017 11:33 am |
Wood
AFTERBURNERS!!! Haha thanks for the input, maybe i won't be hassled too much about it on public land.
On another note, about what is the average compression with delta heads and what octane is everyone running? Pretty sure mine was right at 160 stock, and was 172 with Deltas heads. I was expecting more around 180-185 but the deshrouding may have brought it back down. Either way I'm excited to run it, and hope to be getting a Lectron kit and cam from them before long, probably one at a time as budget allows.
I know when I went from a stock 35.5mm to a 42mm keihin on my 400ex after exhaust, cam and 11:1 piston it made a huge difference, much more than I was expecting. Hopefully the lectron will be a similar shot for a prodrive.
| Wed Feb 22, 2017 1:12 pm |
MaXXis85
| Wed Feb 22, 2017 1:15 pm |
Will C
After a run i would pull plugs and check for a lean condition... just in case
| Wed Feb 22, 2017 2:03 pm |
