It is currently Sun Mar 29, 2026 4:05 pm
Reply to topic  [ 10 posts ]
 35 Hp vanguard upgrade help
Post 35 Hp vanguard upgrade help
So I have a stock beavertail 35 hp surface drive and would like to increase speed and load capacity. I have been looking into it online but can't seem to figure out what are the best options. People say to add a mikuni carb kit and aftermarket exhaust and rework the heads. What are the benefits of a single mikuni and double and would it be worth it? also i see people saying stage 1 or stage 2 what does this mean? Also what can i expect for gains when adding a mikuni and aftermarket exhaust? thanks in advance
Sun Mar 05, 2017 11:33 am
Post Re: 35 Hp vanguard upgrade help
Stage 1 ?? = heads, carb, and exhaust.
you will definitely like what it does for your motor.
Carb and exhaust, will do good also. Mikuni will get you a better idle.
But if you have a non CDI motor, advance timing key. With a CDI, advance timing key($3-$5) but not more than a #4.
premium non ethanol fuel helps, and if you can get access to aviation fuel(100 octane LL what I get).
There are lots of opinions and few options. I know some have other views, I've got a CDI Stage 1 ?? and like what it did for my motor, gained 5 mph and can run a hammer prop at 4000 rpms. Waiting on a advance timing key to see if it helps or hurts.
If you have an EFI motor even fewer options.
Tue Mar 07, 2017 7:38 pm
Tue Mar 07, 2017 8:35 pm
Wasn't thinking of that. BTW are the heads the same? If I bought a new EFI motor could I take my Heads off old motor and use them on EFI? Does the exhaust(if replaced) have to have a threaded bung whole for an O2 sensor?
Wed Mar 08, 2017 8:51 am
Not sure about the bung, but don't think it does. Yes, the heads are the same. When they were originally released, the reps thought there was a difference, but it's only a better valve seat (it still leaks and shifts like the old ones, but is a bit better from the factory).
Wed Mar 08, 2017 9:33 am
I like a heads, cam, and exhaust motor. It fits the needs of most people who need an extra grunt.
Wed Mar 08, 2017 11:07 am
The only difference in the 35 heads and 37 is the valves are bigger.
Wed Mar 08, 2017 11:47 am
Wed Mar 08, 2017 1:07 pm
^^^^^^ yeah what he said :lol:
Mon Mar 13, 2017 2:16 pm
They will still leak and show daylight around the seats after a few hours.
Mon Mar 13, 2017 2:21 pm
cron
