It is currently Sat Jun 28, 2025 8:20 pm
[ 6 posts ] |
fowl habbit
Joined: Sat Jan 16, 2010 1:52 pm Posts: 1130 Location: THE ONE AND ONLY BUFFALO COUNTY
 Leak Down Test Update
I had a leak down test done on the motor and I was 6% on cylinder 1 and 8% on cylinder 2. I also ran another compression test after it was warm and it did a little better. I had 156 and 152 I think all in all everything is good. It seems like my motor might just be one that deosnt have really high compression. Also do you guys notice with the carb and exhaust and heads done that it runs really rich on the idle I smell a little gas on my air filter and once in a while it backfires when I start it back up its like it loads up on the end. Thanks again for all the help with the motor It ran great again today.
Mon Mar 22, 2010 3:57 pm |
deadbird8
 Re: Leak Down Test Update
You can adjust the idle air mix and idle jet on the mikuni
You have a tuning manual?
Mon Mar 22, 2010 4:18 pm |
fowl habbit
Yeah thats what Im going to try. Im still gettin a little fuel to drip out the vent tube when Then motor is in the trave posistion. Other than that very happy with the motor
Mon Mar 22, 2010 5:15 pm |
bjg
Joined: Thu Jan 15, 2009 7:34 pm Posts: 882 Location: Ahead of you, with a rubber band turning my prop!!
_________________ BUCK OFAMA
Mon Mar 22, 2010 6:00 pm |
deadbird8
Mon Mar 22, 2010 9:10 pm |
fowl habbit
I adjusted the float tab a little and that seemed to help I might go to the local harley shop and get a couple different size pilot jets and maybe a one size leaner needle jet. I fim correct its only the straight protion of the needle that changes rich or lean as far as from 0-1/2 throttle I dont want it any leaner on the top end just on the low end
Tue Mar 23, 2010 8:08 am |
[ 6 posts ] |
Users browsing this forum: No registered users and 154 guests |
