joshjc
 more rpm for briggs 23hp
What all are you guys doing to get the rpms up on the small blocks and how high are you getting?
| Mon Apr 17, 2017 8:39 am |
therocket95
 Re: more rpm for briggs 23hp
| Wed Apr 19, 2017 3:18 pm |
flint87
| Wed Apr 19, 2017 3:46 pm |
joshjc
modded. I was just curious how high people were going
| Thu Apr 20, 2017 3:49 am |
MaXXis85
5k plus when the right parts are installed.
| Thu Apr 20, 2017 6:12 am |
joshjc
that's about where I wanna be
| Thu Apr 20, 2017 10:46 am |
redfish bandit
| Thu Apr 20, 2017 12:51 pm |
goodblasson
Joined: Fri Apr 30, 2010 11:26 am Posts: 254 Location: Lafayette, La
rev limiter 4700. Can almost turn 5K with a moderate load when rev limiter is unplugged. Motor is modded. I try not to run over 4300, trying not to blow up this motor. Over 400 hrs on modded motor.
| Thu Apr 20, 2017 3:36 pm |
huck Finn
Joined: Thu Jan 31, 2013 5:42 pm Posts: 1913 Location: Conroe tx
I like to cruise around the 4600 mark. Heavy load around 42-4300.
H Finn
_________________ Ole black water keep on rolling
18x54 Uncle J -GTR - with the koolaid Back H2o SWOMP 23 SS stage 2 15x36 GD Duck Skiff GATOR GATOR GLIDE PROSTAFF BACKWATER PROSTAFF http://www.gatorglide.com
Coupe rest in peace brother
| Thu Apr 20, 2017 9:17 pm |
nuccifish06
Joined: Tue Sep 16, 2014 6:36 pm Posts: 108 Location: Sunrise, FL
Huck, on my 23 can I get there with stock carb, manley valves, shimmed springs, high rev valve stems, thin head gaskets and timing key? Or do I need a cam some other stuff? and more $$$
_________________ 1438 Jon / 23hp MBLT
| Fri Apr 21, 2017 8:40 am |
SETx Longtail
Joined: Sun Sep 01, 2013 2:53 pm Posts: 3480 Location: Hardin County, Tx
Keep digging in that wallet...
_________________ #CFFITR
-Custom pool noodle -stage 4 water wings
| Fri Apr 21, 2017 1:02 pm |
flint87
| Fri Apr 21, 2017 1:12 pm |
MaXXis85
Rods, pistons, carb, thin head Gaskets, Repair the factory heads from crushing, cam, and adjust timing if needed. It will be a hot rod mamma jama!
| Fri Apr 21, 2017 1:18 pm |
joshjc
ive got modded heads, mikuni carb, cam but im not done im going to go back into it and do crank,rods,and pistons end of summer just cant figure out if I want to do 2o or 30 over pistons yet,
| Mon Apr 24, 2017 10:44 am |
