It is currently Thu Apr 02, 2026 4:16 am
Reply to topic  [ 2 posts ]
 Question on upgrading small mm size from 16hp to 22hp
Post Question on upgrading small mm size from 16hp to 22hp
I have a Backwater SWOMP Lite kit on a 420cc predator...thinking of upgrading to the 670cc predator. But was wondering if simply upgrading size will give me much more performance.
Currently, the 420cc is modded, turning a 9x6 prop and will not exceed 3900-ish rpms in the water with this setup. Speed around 18-19. I assume that big prop (for that size engine) is what's limiting my max rpms.
Thinking a 670cc would give it more torque, but not really much more to offer since it's governed likely at 3600.
Is it worth messing with?
Fri May 05, 2017 1:02 pm
Post Re: Question on upgrading small mm size from 16hp to 22hp
I have a 22hp Predator in a Go Devil frame and can't get more than 4,000rpm spinning a 9x6. The only time I think you would see more speed is if loaded Heavy where he 22hp torque could make a difference. You will definitely have to zip tie the governor spring to get more out of it.
Go Devil 1860 35 GDSD
Weldcraft 1548 22hp Predator GDLT
Sun May 07, 2017 6:16 pm
