It is currently Thu Apr 02, 2026 4:25 pm
BSD Efi heads, cam, exhaust, and tuner install
Russ
 Re: BSD Efi heads, cam, exhaust, and tuner install
You know exactly what to expect. No surprises.  Sent from my SAMSUNG-SM-G891A using Tapatalk
| Fri May 05, 2017 9:40 am |
cb5331
Idindonuffin
| Fri May 05, 2017 9:54 am |
MaXXis85
I turned the lope screw on.... Might turn it off
| Fri May 05, 2017 10:25 am |
SETx Longtail
Joined: Sun Sep 01, 2013 2:53 pm Posts: 3480 Location: Hardin County, Tx
Are you doing all of this with a fuel tuner? Or do you have a way to get into the rest of the ECM (spark tables etc)
_________________ #CFFITR
-Custom pool noodle -stage 4 water wings
| Sat May 06, 2017 7:56 am |
MaXXis85
| Mon May 08, 2017 5:09 am |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
So when the hell u going to let us see what's this new product or whatever the hell u was talking about?
| Wed May 10, 2017 9:25 am |
cb5331
It's a chrome bayou surface drive emblem that you screw on to the blower housing. They're $600. Most people are seeing gains of around 6hp with this easy to install mod.
| Wed May 10, 2017 9:32 am |
MaXXis85
| Wed May 10, 2017 10:22 am |
pokey79
Clay always being a DICK!!!!!!!!!!!!!!
| Wed May 10, 2017 3:38 pm |
MaXXis85
Richter Customs 1854 3/16" bottom mod vee rake Heads, cam, tuner, Mercury 3 blade prop worked to 11.75x11.5 pitch Boat was ran in deep water only for testing and tuning Acceleration afr off idle is 12.7-13 Cruising is right at 13 Wot is 12.5 AFR. If I lean Wot to 12.75-12.9,I see the cruise afr at 13.3-13.5 AFR. I richened it back to 12.5 and the boat runs great. Other than the slip on takeoff with the mercury prop this thing has power throughout the rev range. It planes out quickly and is very responsive to the throttle. This cam seems to be something I will keep. When cruising at 30mph if I mash the throttle this thing will set u back and get right up to max speed. It runs best speeds at 4680-4700 any more trim the bouncing is bad and the prop gets into the rhythmic action of rev limiter on-off-on-off. I'm very pleased with this simple build for an all around hunting and fishing motor.
| Thu May 11, 2017 5:58 am |
Will C
Hell yeah!! Glad she is running good!
| Thu May 11, 2017 7:20 am |
cb5331
Nice!
| Thu May 11, 2017 7:27 am |
MaXXis85
I will get an accurate compression check for those minds inquiring.
| Thu May 11, 2017 7:37 am |
pokey79
Can't be its 9 hours later and no compression numbers yet!!
| Thu May 11, 2017 3:49 pm |
Russ
It doesn't exist. I just left his house/shop. It's a unicorn.
| Thu May 11, 2017 6:45 pm |
MaXXis85
Damn, Can't catch a break! Not like I'm busy... LOL. I will get yall some numbers. Had to take care of some other things yesterday evening.
| Fri May 12, 2017 5:53 am |
