It is currently Sun Mar 29, 2026 2:32 pm
Reply to topic  [ 6 posts ]
 23 h.p Vangard Case Gasket
Post 23 h.p Vangard Case Gasket
Today I went out to my motor and saw my oil sitting on the ground. It appears to be coming from the bottom of the case gasket of the motor. I hand check the case bolts and number 5 & 7 bolts ( middle 2 bolts on right side.) were loose . I tried to tighten them and they kept turning. I think they are stripped or broke ?? . Either way I don't want to continue to run my motor like this. I'm not familiar with mud buddy outdrives and I'm wondering how much work it is to pull everything off and what's the easiest way. Any advise would be great! Motor is a 23 mud buddy HD
Tue May 09, 2017 9:57 pm
Post Re: 23 h.p Vangard Case Gasket
Yours is really not too bad. There might be some how to stuff on the bps website
Tue May 09, 2017 11:10 pm
Wed May 10, 2017 5:04 am
Ok so I'm stuck. I have everything apart but cannot get the clutch gear to come off. I tried to get a gear puller but it won't work with the clutch plate in the way. Any help?? It's been soaking in PB blaster for 2 days now
Thu May 11, 2017 7:27 pm
Www.posilock.com
Thu May 11, 2017 7:32 pm
Fri May 12, 2017 5:56 am
