It is currently Tue Mar 31, 2026 6:55 am
Reply to topic  [ 7 posts ]
 New motor compression test
Post New motor compression test
Hey guys. I'm meeting up with a seller this week. Buying a 1748 x series with all stock 36 hp prodrive on the back.
Looking to run a compression test on it. I've done a few before but never on the 36 Briggs. Just making sure I have the right tools here at lsu with me. Will I be able to get away with a 5/8 or 13/16 wrench or is there not enough room for that? If not, I'll need to go buy some deep sockets. Thanks for any input guys. Also, what psi should the gauge be reading for these motors stock? I'd imagine around 120-140.
Sun Mar 19, 2017 5:01 pm
Post Re: New motor compression test
Thin wall deep socket or you may have to pull the heat shields to get to the plugs. Don't remember the size for the champion plugs. It's different than the autolites I run. Make sure you hold the throttle wide open while turning the motor over.
Sun Mar 19, 2017 5:32 pm
Sun Mar 19, 2017 6:04 pm
5/8 socket, remove plugs, run test with throttle WIDE OPEN. kill switch pulled so there is 0 spark
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Mon Mar 20, 2017 6:07 am
Mon Mar 20, 2017 3:53 pm
what was the cmpression ? why hold throttle open?
Tue May 30, 2017 6:54 pm
Bayou Surface Drive
337-351-0362
Wed May 31, 2017 6:27 am
