It is currently Sat Jun 28, 2025 7:24 pm
Reply to topic  [ 12 posts ]
 MB New 3 Blade
Post MB New 3 Blade
Do any of you have any No: on what MB new 3 blade will do on a MB7000 on a Excel 1751?
If you cant run with the big Dogs stay on the Porch
Thu Mar 11, 2010 8:46 am
Post Re: MB New 3 Blade
Go check out the mud bud forum,that is your best bet.
Thu Mar 11, 2010 8:52 am
i ran 2 different MB 3 blades with mixed results.
1 did okay for what you may encounter during a normal fishing day and the other comletely sucked. It totally flattened out after 4k RPM's. Niether did well in the mud. They both did fairly decent in the veggies and worked well in reverse.
Thu Mar 11, 2010 11:02 am
Coondik give me somemore info rpm,etc just bought a three blade 12x10.5 for Harley Mud Motor haven't run it yet, I am remaking crankshaft stub, still having issues with the flywheel sheering key making the shaft tappered were the flywheel locks on. Hopefully will pull two all nighters trying to get it back this weekend.
There is no replacement for displacement!!!!
Thu Mar 11, 2010 11:17 am
10 4!
Let me do sum diggin'
Thu Mar 11, 2010 11:24 am
The one I have seems to be ok in the veggies and clean water. It is stamped 12.3X9. Turned up to 4500 at 35-36mph. It held my 1852 Extreme on step at 2400-2500 rpms. It does take some power to turn it. I am runnning it with my 31HP Stage III.
Thu Mar 11, 2010 11:40 am
drake any idea how hp's the generac is putting out.
Thu Mar 11, 2010 11:58 am
MMT Moderator
I watched QuackKiller08 change his prop on his MB like 5x one day he was going back and forth between the 3 blade & 2 blade. He ended up running the 2 blade for the rest of the day... Might want to shoot him a PM and get his take on the two. He tested them in some nasty stuff!
GTB 1860 w/ 2019 GTR40XD-HO
Thu Mar 11, 2010 12:06 pm
OK thanks for the help it look to me that it wouldn't work or do you think the 7000 has the hp to make it do something.
Thu Mar 11, 2010 1:00 pm
ran a 12.3X9 with same results as drake1.
last one i tried was a 12.25x12. could turn it well over 4k but there was no point cause it just blew out. i think the best speed was around 29mph @ de 4 thousand mark. put in on another stage 1 GTR wit de same results. i think prop was purpose built for a stock motor!
Thu Mar 11, 2010 2:26 pm
Looking at buying the three balde prop from BPS for my 23 hp GDSD. With basically a stock motor, will I have enough muscle to benefit from it? Don't run in much mud here either. I am looking at installing BPS exhaust and a single mikuni carb kit, will that help?
Dave
Tue Mar 16, 2010 8:17 am
go-devil puts a three blade on there new ones now so i would think it would be fine.
Starting to wonder why my mother always called me special.
1750 GatorTrax HDeck 45 performance v-twin marshmellow double barrel exhaust
premium oak reverse w/minnkota cruise control
Wed Mar 24, 2010 12:37 am
Users browsing this forum: Majestic-12 [Bot] and 95 guests
