It is currently Sun Mar 29, 2026 6:13 am
Reply to topic  [ 5 posts ]
 Prodrive starting problems
Post Prodrive starting problems
I was put in a duck blind yesterday ran fine no problems whatsoever went to get the last few pieces of the blind went to turn my motor on all it would do is make one click...... bought a new starter put it on...... same thing happened again.... turn the key and one click and that's it..... what do I need to look at or into..... any help would be much appreciated
Tue Aug 15, 2017 10:34 pm
Post Re: Prodrive starting problems
Did you verify a good connection at the batter?
Did you change the solenoid on the starter?
you may even have a dead battery
Wed Aug 16, 2017 5:23 pm
I would call prodrive in the morning. Their support is top notch.
2016 Prodrive X 1848 37efi
Wed Aug 16, 2017 5:31 pm
That really sounds like a bad connection, dead battery or weak power on the yellow trigger wire.if connections are good and battery is hot try jumping the male connecter on the starter solenoid staight to the main battery connection on the solenoid. This will check for weak trigger wire
Wed Aug 16, 2017 11:27 pm
Had this happen. It was draining batteries. Voltage regulator was bad on mine.
Wed Aug 23, 2017 11:46 am
