It is currently Sat Apr 04, 2026 9:26 am
Reply to topic  [ 6 posts ]
 NEED SOME HELP!!older model gator tail w/cranking issues!!!
New Member
Post NEED SOME HELP!!older model gator tail w/cranking issues!!!
Hey all! I have an older model Gator tail tiller powered by a 35 hp Vanguard. Sometimes it starts :D , sometimes it just clicks and won't turn over :cry: . I thought it was the starter, so I replaced it and it still did the same thing :shock: . Next, I replaced the ignition switch, same problem :evil: . The clutch switch appears to be working properly. Any suggestions on what to try next?? Thanks in advance for your response!! :mrgreen:
Thu Aug 24, 2017 2:56 pm
Post Re: NEED SOME HELP!!older model gator tail w/cranking issues
Did you replace the solenoid on the starter?
What about your 12 volt wire going to the solenoid?
Refurbishing a Prodrive
Sat Aug 26, 2017 6:39 pm
Check the voltage on that yellow wire going to the starter solenoid, and charge your battery.
#TheGhostBoat
Sat Aug 26, 2017 9:25 pm
Yep^^ low signal power on that yellow wire, unless the obvious battery connections are shit
Sat Aug 26, 2017 11:16 pm
New Member
Thank you all for your responses!! i checked the 12 volt wire to the starter and it was dead. turns out it was a corroded wire from the kill switch! Thanks again!
Fri Sep 01, 2017 7:30 am
Glad you found it
Fri Sep 01, 2017 7:32 am
