It is currently Sun Mar 29, 2026 6:19 am
Reply to topic  [ 3 posts ]
 Need help with mud buddy outdrive
New Member
Post Need help with mud buddy outdrive
My original sport shaft cracked and I just got a new one to replace it but the new one is a little different. On the prop end the old unit stuck out a bit so prop didn't touch the drive but the new one is recessed. Do I need some kind of washer because the prop is flat in the back and will hit the drive?..... Second question the front of the new unit uses a woodruff key under the pully and the old unit uses a square key. Someone mentioned that a washer should be behind the Pully too. Do I need to do anything besides change the key?.. I will try to post pictures. Thanks in advance Eric
Fri Sep 01, 2017 8:35 pm
Post Re: Need help with mud buddy outdrive
You'll need the spacer that goes behind the clutch and an .060 spacer between your prop hub and bearing/seal housing. Call bps or
Mud buddy they have everything in stock. You can also call The boat doctor in La. Andy has everything in stock and will ship quickly as well.
1854 Prodigy Open
HDR/Stage 3 mods
Prodigy Boats Pro Staff
BPS Swamp Staff Member
Blackwater Marine LLC.
Sat Sep 02, 2017 3:20 pm
New Member
Thanks smoke.
Mon Sep 04, 2017 6:31 pm
