It is currently Sun Mar 29, 2026 6:14 am
[ 9 posts ] |
Ricerunner
Joined: Fri Sep 11, 2015 6:56 pm Posts: 887 Location: Summerville, SC
 Bigger intake valves?
Has anyone ran bigger intake valves? I'm looking to make some more power. I am currently running a .045 deck port & polished .308 Peltier cam mikuni and stock gutted. I don't want to change my rocker assemblies.
| Mon Sep 04, 2017 7:31 pm |
Will C
 Re: Bigger intake valves?
Most head suppliers use bigger intake valves. Even the 37efi uses an intake valve thats bigger than the carb motor
| Mon Sep 04, 2017 7:43 pm |
NannySlayer
Joined: Sun Feb 03, 2013 11:49 pm Posts: 456 Location: S.C.
_________________ 17/54 gator Trax 35 mudbuddy... mostly stock
| Mon Sep 04, 2017 10:57 pm |
banded-mallard
I truly believe that's why e get so much torque from the kawi, we have 2 intake valves per head for a 6 valve arrangement. Its just finding the right cam and other shit to get the maximum power.
| Tue Sep 05, 2017 4:41 am |
MaXXis85
You want the approx 80% ratio difference from intake Diameter to exhaust. Really the stock exhaust is big for these motors already. A larger intake valve will work well. Here is the tricky part you can just put a larger intake valve without LOTS of seat work. A larger valve in the same seat dimensions will just hinder flow because it will shroud the seat that much more. You sink that valve in the seat and open it up to meet the valve seat/throat ratio then you have to trim stem length to keep the geometry in spec.. There is a lot more to it than just putting a larger valve...
| Tue Sep 05, 2017 6:14 am |
Ricerunner
| Tue Sep 05, 2017 7:16 am |
Ricerunner
Maxxis.... Marcus?
| Tue Sep 05, 2017 7:57 am |
Will C
Same feller
| Tue Sep 05, 2017 8:04 am |
MaXXis85
Rollers aren't the issue. Its lack of seat pressure for aggressive cams along with SHITTY castings.
| Tue Sep 05, 2017 8:11 am |
[ 9 posts ] |
