It is currently Sun Mar 29, 2026 6:10 am
Reply to topic  [ 2 posts ]
 Gatortail Key Switch PN
Post Gatortail Key Switch PN
On my '08 Gatortail I am not getting a spark while the engine is cranking and I only get spark once I let off to the run position (and then the engine usually fires right off or I get one hell of a backfire). From what I have found it looks like it may be a key switch issue, but can't find the appropriate part number to replace it with. Does anyone have it readily available? I would like to get a drop in replacement and not have to rewire anything.
BTW, it is an 08 Gatortail that was upgraded with the tiller control box.
Thanks!
Fri Sep 08, 2017 12:20 pm
Post Re: Gatortail Key Switch PN
Go to the Auto parts store and match it up to the same plug you have. Its a lawn mower key switch.
Fri Sep 08, 2017 12:58 pm
