It is currently Sun Mar 29, 2026 6:11 am
Reply to topic  [ 12 posts ]
 Best way to mod a stock exhaust?
Post Best way to mod a stock exhaust?
What's the best way?
1. Make the 1 outlet larger?
2. Add 2 additional outlets?
3. Gut it entirely and weld the caps back on?
4. Something else?
FTR, this it for a 37 hp efi motor. Want to keep it as quite as possible while giving it better flow for heads, cam and programmed Ecu.
WC Custom 1854
Sun Sep 10, 2017 2:20 pm
Post Re: Best way to mod a stock exhaust?
Sun Sep 10, 2017 4:53 pm
Yeah it won't be quiet but sounds good imo. I use a stock exhaust for hunting and gutted one for the rest of the year
Sun Sep 10, 2017 5:02 pm
Are there any potential problems associated with running mods without a high flowing exhaust?
WC Custom 1854
Sun Sep 10, 2017 5:07 pm
Sun Sep 10, 2017 5:13 pm
Mon Sep 11, 2017 5:13 am
When I gutted mine I didn't completely gut it. I cut the ends open drilled about 20 1/2" holes in baffle on each side, got a long bit and put about 10 holes thru and thru on the outlet, welded the ends back up. Been running like this for about 90hrs so far. Sounds like a bps q and there was no rpm change between a Mac single outlet and this exhaust. On previous motors I've completely gutted them and they usually only last about 50 hrs before they start falling apart without the internals. Hope this helps ya out
Sent from my SAMSUNG-SM-G891A using Tapatalk
Gen III Pro Drive with a JBP stage 2 pushin 18x54 madmancustom
Jus nut up and grab a handful of throttle
Mon Sep 11, 2017 6:28 am
Note: I did this on my prodrive and the exhaust hangs below the motor so I wasn't as worried about getting a metal shaving falling down into my motor
Mon Sep 11, 2017 6:32 am
Ive gutted a few in the past. I figured out that when fully gutted you have to weld a reinforcement plate under tailpipe or it will be blown to pieces from both headpipes being aimed right at the tailpipe. It cherries up and falls apart. Also with a normal size outlet the pulses bounce back up into the oposite cylinder during vavle overlap instead of being scaveged. With a big tailpipe its not so bad but then it gets loud. My 2c for the day
Mon Sep 11, 2017 10:12 am
This one sounds good but is a bit loud, couldn't see any performance difference between it and a MB Y Cross over. At least it hasn't cracked after 70+ hrs..
Mon Sep 11, 2017 12:03 pm
Edit
Mon Sep 11, 2017 12:38 pm
Mon Sep 11, 2017 2:33 pm
