It is currently Mon Mar 23, 2026 4:14 am
[ 4 posts ] |
22 hp vangaurd go devil longtail problems
Buckshot7
I just purchased a 16ft tracker grizzly with a 22 hp vanguard go devil the other day. Nice boat and motor and took it out for the first time today and ran great the whole day. Was getting it up about 20 mph on the open water. Stopped for a little and went to start it back up and head to the launch and motor would barely get me up to 10 mph full throttle. its was like it would not kick into another gear. It would get up on the rpms if the prop was out of the water but if I put it in it would immediately go down on the rpm and start backfiring. It seemed like all of a sudden it didn't have the power any more to go. Just seeing if anyone may have any suggestions on what the issue may be. Anything would be greatly appreciated. Hope everyone is having a happy 4th!!
| Tue Jul 04, 2017 6:09 pm |
reharbert
Joined: Tue Mar 17, 2015 1:38 am Posts: 606 Location: Beaumont, Texas
 Re: 22 hp vangaurd go devil longtail problems
Check valve lash / push rods, and check that coils are firing. I would start there.
_________________ Uncle J - 17 x 48 w/GTR | Bayou Surface Drive heads | Voodoo exhaust | DIY Mikuni carb
| Fri Jul 07, 2017 10:16 am |
Russ
Air leak in the fuel line, fuel pump having issues, carb clogged.
Sent from my SAMSUNG-SM-G891A using Tapatalk
| Fri Jul 07, 2017 11:03 am |
PoppinPintails
I have a 23 go devil and have the exact same issue. Had the carb cleaned and no difference. Found gas in my oil. Talked to several people and most suggested buying a new carb. Will update when I purchase new cab.
| Mon Feb 05, 2018 1:01 am |
[ 4 posts ] |
