It is currently Wed Mar 18, 2026 1:49 pm
Reply to topic  [ 5 posts ]
 35 Vanguard Governor
Post 35 Vanguard Governor
I just got a new engine with a 2018 block on a older frame so I’m still setting it up. I’m trying to get the rpms to around 3900 or 4K by adjusting the governor out some. But as you can see it’s pretty much out all the way so I was wondering how to get those last few rpms up. Just keep screwing it out more? Right now it’s running around 3400-3500 out of the water
Tue Sep 11, 2018 7:48 am
Post Re: 35 Vanguard Governor
Back that screw back off some or it can fall out of place. Replacing that green spring would be the white way.... put a zip tie through the gov spring and let the coils catch the rpms at 4350
Tue Sep 11, 2018 8:23 am
U could also try just moving gov spring to the slot # 3
Tue Sep 11, 2018 8:26 am
What do you mean put a zip tie through the gov spring?
Tue Sep 11, 2018 8:47 am
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Tue Sep 11, 2018 9:31 am
