Fowl Language
 Fuel issue on new 40 HP.
OK, new 40HP with 1.4 hours on it. I have taken it out 2x and not had an issue. Today I thought I would see if there were any Teal around. Motor fire up just fine. I motored about 1/2 mile at a cruising speed. Motor slowly bogged down and shut off. The motor will turn over, just not fire up and run. I limped back to the dock with the trolling motor and have been troubleshooting since. I have checked the fuel line and tightened all connections. Still nothing. Any thoughts? what I should check. Not versed on the EFI, was getting pretty good with my other Carb motor. This is something new for me. I'm sure it's something simple.
| Wed Sep 19, 2018 8:42 am |
FRANKtheTAU
Joined: Thu Dec 29, 2011 10:30 pm Posts: 1386 Location: West TN
 Re: Fuel issue on new 40 HP.
Is the fuel pump running when you turn the key? How old is the fuel line?
_________________ 40 Backwater SWOMP Lite / 1752 Alweld Mud
| Wed Sep 19, 2018 9:25 am |
Fowl Language
Fuel pump runs. The fuel line is new from BW. I have a water separator and disconnected that and ran the line straight from the tank to the engine. I have a bulb in the line. I've tried pumping it and the engine still won't turn over. Every once in a while, it will sound as if it will run, but just doesn't grab and go. Safety clip is in place, not sure if there are any others that would cause this issue.
| Wed Sep 19, 2018 9:41 am |
Duck_Whisperer
Joined: Sat May 16, 2015 4:52 pm Posts: 33 Location: South Louisiana
Check the vent on the gas cap. Try running with the cap cracked open slightly. My 37 used to do the same thing. Motor slowly would lose power to where it would only idle, then shut off. Needless to say, I removed the vent and its been great since.
_________________ Boat: Godevil 18x56 Motor: 35 GDSD
| Wed Sep 19, 2018 10:30 am |
Russ
So the fuel pump runs, but is the high pressure side seeing fuel? Doesnt sound like it. I dont remember if theres a pump or just a fuel pressure regulator, but that sounds like the potential issue.
| Wed Sep 19, 2018 10:47 am |
Fowl Language
I've tried the tank vent cap. Opened some and a lot and also closed. Not help.
Russ, "high-pressure side seeing fuel?" Not sure where to look or check got this. I'm wondering now if I need a pro to look at it. Flint Tx is a drive, but I might have to make it.
| Wed Sep 19, 2018 11:18 am |
Fowl Language
Curious, in the fuel line to the motor there is a fuel filter, then a silver filter that has wires connected to it. What is that?
| Wed Sep 19, 2018 11:20 am |
Will C
The silver filter with wires is the low pressure pump that feeds the black resivoir under air filter that has the high pressure pump inside it
| Wed Sep 19, 2018 11:24 am |
Fowl Language
Thanks for the lesson on what is what. Will, I sent you PM. Let me know your thoughts.
| Wed Sep 19, 2018 11:38 am |
FRANKtheTAU
FWIW I don't run a primer bulb and I never have on any of my EFI motors.
| Wed Sep 19, 2018 11:55 am |
Russ
It's not a necessity until the low pressure fuel pump dies while on the water. Then it's as handy as a pack of almond Hershey kisses at an orgy.
| Wed Sep 19, 2018 1:09 pm |
huck Finn
Joined: Thu Jan 31, 2013 5:42 pm Posts: 1913 Location: Conroe tx
" Almond"
H finn
_________________ Ole black water keep on rolling
18x54 Uncle J -GTR - with the koolaid Back H2o SWOMP 23 SS stage 2 15x36 GD Duck Skiff GATOR GATOR GLIDE PROSTAFF BACKWATER PROSTAFF http://www.gatorglide.com
Coupe rest in peace brother
| Wed Sep 19, 2018 1:23 pm |
Duck_Whisperer
Is the fuel bulb in the front or back of the boat? On a 35 I did some troubleshooting on for a buddy, with the bulb in the back the motor would run the gas out of the line, then shut down. With the bulb in the front, it did not have any problems. Just a thought...
| Wed Sep 19, 2018 2:31 pm |
Roostertail3
Joined: Sun May 22, 2016 10:32 am Posts: 334 Location: Middle ga
take that bitch to where you bought it from and have them fix it.
| Wed Sep 19, 2018 3:13 pm |
Fowl Language
Diag: Despite having a water separator, there was water in the gas!
Made the trip and met Will C and his brother-in-law. Will told me he closed at 4 pm, but might be there a little later. I arrived at 3:45. Because of my 3hr drive, Will stepped up and looked over the engine and diagnosed the problem within about 10 min. An hour later, due to some great conversation and me hang out causing delays. I was back in business.
Thanks again Will. Go see this guy!
| Wed Sep 19, 2018 8:08 pm |
Will C
Thank you for driving out here. Glad it was an easy fix. Always fun to meet folks like yourself. Apologies for miscommunication as I'm in here till 5 most days. I wondered why you said thank you for staying late when it was 5, lol. Holler if u need anything
| Wed Sep 19, 2018 11:23 pm |
MaXXis85
That Will C. He is good people
| Thu Sep 20, 2018 6:33 am |
FRANKtheTAU
Good deal!
| Thu Sep 20, 2018 12:09 pm |
