It is currently Fri Mar 20, 2026 12:36 pm
[ 9 posts ] |
BMR1214
 Pro Drive 35 hp
Looking for information and opinions on stage 2 Performance kits. Thanks
| Sun Dec 02, 2018 1:27 pm |
Will C
 Re: Pro Drive 35 hp
Everyone's stage 2 is different. A good stage 2 motor will be a a lot more fun to drive than stock. Load carrying ability goes way up also
| Wed Dec 05, 2018 12:26 pm |
banded-mallard
 Re: Pro Drive 35 hp
PD is 36, 37 or 40. What year model do you have? CDI or NON-CDI? Will make a difference depending on your mods and what you want to do. CDI are protected by 4750 coils when adding performance parts. So your cam will dictate that. Non-cdi has no limiter and will spin to the moon and will blow up if you don't know what your doing. Each has plus and minus.
| Thu Dec 06, 2018 9:19 am |
BMR1214
 Re: Pro Drive 35 hp
I have a 36 hp NON-CDI. Also what do y’all think of the MAC Muffler?
| Thu Dec 06, 2018 9:21 am |
banded-mallard
 Re: Pro Drive 35 hp
Exhaust is a very small piece of the pie when considering performance. Any free flowing exhaust will do just fine unless your in the "hey look at my new shiny $700 exhaust" crew. You can take a stock exhaust, gut it, and it will flow just as good as all these high end exhaust. You would need a dyno to tell the difference. AND....... they all crack at some time. its just the nature of the SS. When I did my mod on my old engine, Heads are #1. You can put all that fancy shit on it you want, but if the engine can't breathe, it won't run. Everything else you do after heads will be complimentary.
| Thu Dec 06, 2018 9:46 am |
banded-mallard
 Re: Pro Drive 35 hp
read this. I did mine in different stages and noted the changes when I modded my 07PD NON-cdi. Gives you an idea of what to expect. UNLESS..... you have a gen3 lower, then all speeds will be slower.
| Thu Dec 06, 2018 9:52 am |
brycecheramie
 Re: Pro Drive 35 hp
You can say that again!
| Sun Dec 09, 2018 1:38 pm |
Wchauvin
 Re: Pro Drive 35 hp
Are the gen 3 lowers slower because they are geared differently?
| Sun Dec 09, 2018 1:46 pm |
banded-mallard
 Re: Pro Drive 35 hp
Yes
| Sun Dec 09, 2018 2:20 pm |
[ 9 posts ] |
