It is currently Tue Jun 24, 2025 6:28 pm
Reply to topic  [ 9 posts ]
 27 hp Pro-Drive to Big Block
Post 27 hp Pro-Drive to Big Block
Looking at swapping out 27 hp Kohler to a big block. What options are there that will mount up? Do they have same bolt pattern? Any other considerations?
Thanks in advance
Sat Aug 10, 2019 4:35 pm
Post Re: 27 hp Pro-Drive to Big Block
Bout swap mine to a 36 after duck season ain’t looked far into it yet
Sat Aug 10, 2019 6:20 pm
Yes, should be the same bolt pattern.
May have to make the bolt holes bigger but im not 100%.
Just be sure you get the correct output shaft on the 36.
Refurbishing a Prodrive
Sun Aug 11, 2019 5:50 am
Swapped out my kohler for the kawasaki FX1000V last year and dont regret it one bit. The kawasaki has a lot of power. Bolt pattern was the same, just had to drill the holes out as the kawasaki mounts with 3/8 bolts. Only thing you have to figure out is the exhaust and throttle which isnt bad at all. If you have any questions get a hold of banded-mallard he knows a lot about these motors and helped me out a lot.
Sent from my SM-G892A using Tapatalk
Sun Aug 11, 2019 7:24 am
I have a 25 Kohler efi on my prodrive now and a used 36 engine from a prodrive thinking bout swapping . What y’all think bout going from a efi to a carb motor ? That’s really only hold up dealing with it in winter time hunting. Just looking for opinions
Sun Aug 11, 2019 12:39 pm
Sun Aug 11, 2019 3:15 pm
West Tn not like gets extreme cold like way up north . I know had carbed ones long time , figure the extra power from big block be a plus anyway over the efi Kohler . Least can get a lot more aftermarket parts also don’t plan I running stock motor anyway when I swap it
Sun Aug 11, 2019 8:16 pm
Sun Aug 11, 2019 8:24 pm
True , and If weathers like last year ain’t worry bout weather less then 60 degrees anyway
Sun Aug 11, 2019 8:33 pm
Users browsing this forum: No registered users and 130 guests
