It is currently Fri Mar 20, 2026 9:12 am
Reply to topic  [ 10 posts ]
 2011 23 hp GoDevil SURFACE DRIVE
Post 2011 23 hp GoDevil SURFACE DRIVE
Just bought my first mud boat. Downloaded the manual greased all exterior points. motor started right up idled it for about two minutes. Revved it up held it for about ten seconds let of idled back down got back on it then motor locked up. I haven’t called GoDevil yet plan on doing that tomorrow. Anyone know of rebuild kits out there? Did a quick google and a lot of different ones pop up.
Wed Dec 11, 2019 9:42 pm
Man by the looks of that spark plug you had a hell of a wreck inside of that cylinder. My guess is you’ll need a short block rebuild. You can call a briggs dealer for one or type in your model number to a small engine website to find one yourself. Let us know what godevil says or what you find if you tear into it yourself.
Fri Dec 13, 2019 10:56 pm
Post Re: 2011 23 hp GoDevil SURFACE DRIVE
Well here is the after math dropped a valve and well you know what happens after that. Talked to coco haven’t looked at the cylinder yet to scared to take off the head lol. But if nothing is chewed up which I doubt the have heads they can sell me. I’m gonna get the head off today and will let you guys know the aftermath.
Sun Dec 15, 2019 9:04 am
Here’s the piston cylinder didn’t get scared up at all.
Sun Dec 15, 2019 7:13 pm
Never seen a valve come through the head like that. Pretty neat.
Sun Dec 15, 2019 9:06 pm
That's a bit different valve geometry you got on there. Probably not as efficient as what Briggs had in mind.
#GhostBoat
Sun Dec 15, 2019 9:19 pm
It’s got a triple angle.
Mon Dec 16, 2019 8:30 am
Ouch.
Mon Dec 16, 2019 10:42 am
Did you try JB Weld?
Mon Dec 16, 2019 11:44 am
Also threw the governor weights off.
Wed Dec 25, 2019 11:21 pm
