It is currently Tue Jan 13, 2026 12:26 am
Reply to topic  [ 3 posts ]
 2008 36 prodrive Rpm drop
Post 2008 36 prodrive Rpm drop
After about 2 or 3 minutes, losing about 200 Rpm. Last 3 trips all about the same. 525 hours. Any suggestions
16 x 48 Alweld - 36 PD FPR PT&T
Mon Apr 27, 2020 4:30 pm
Post Re: 2008 36 prodrive Rpm drop
That could be a lot of things. Fuel starvation, coil or electrical part heating up, and plenty of other potential causes. Any more info you can provide?
Mon Apr 27, 2020 7:01 pm
I found another post about the same thing, same model. It noted about plug cap. Checked the plug / wire and found something white between the plug and cap. I do run salt water. Cannot believe I did not check this first. Will test this weekend. Thanks again for the help.
Mon Apr 27, 2020 7:28 pm
