So you do you have what EVT put on or what BB has tricked out for everyone? If you have a short cable connected to the factory throughtle stop with a simple clamp the the below applies. If you have BB setup IDK...
The only way to change the % of rotation before WFO is to change the size of you rotating shaft.
Think of it like a chain sprocket on a 10 speed and you should ge the jest of it...….. If you get a aftermarket twist grip you will have almost ½ turn before WFO....if you want to try one out shoot me a PM with you address and ill put mine in the mail. If you like it we can work something out.
Later
