It is currently Fri Jan 30, 2026 2:37 am
Reply to topic  [ 3 posts ]
 Intermittent Flooding issues 35 hp vanguard
Post Intermittent Flooding issues 35 hp vanguard
I got a 35 Vanguard that keeps flooding out on me when I run wide open throttle and let off. It’s very intermittent and I can’t figure it out. New carb, I inspected the needle and seat. I pulled the vent for my gas tank. My next thought is that there’s pressure building in my fuel water separator when it’s exposed to direct sunlight. I noticed my fuel filter had filled up today with my gas shut off off and the vent out of the tank. I unscrewed then separator and I heard hissing and had gas spraying out. Other than the tank and carb what else could be my issue?
Mon Aug 24, 2020 3:08 pm
Post Re: Intermittent Flooding issues 35 hp vanguard
U could drop float level a hair also. Melt off idle fuel limiters and dial in the idle fuel. Set up the governed idle spring. Set valves. For any engine with an idle issue i run a leakdown. Often find heads in need of valvejobs
Mon Aug 24, 2020 10:31 pm
Thu Aug 27, 2020 5:50 pm
