It is currently Fri Jan 30, 2026 4:14 am
Reply to topic  [ 4 posts ]
 Which offset timing key?
Post Which offset timing key?
Briggs 32 with .050 decking and shaved pistons, Mikuni HSR carb and Marshmellow exhaust.
I've searched but didn't find an answer. How much offset would be recommended to optimize performance?
32 PD with EVT cam, decked heads, shaved pistons and not enough sense to leave things alone!
Sun Oct 11, 2020 7:09 pm
Post Re: Which offset timing key?
I would use a 2or 3 deg key for a total of 25/26 degrees
Sun Oct 11, 2020 9:33 pm
Posting pic here because i cant send it To your pm. I would try a number 2 first. If u feel a huge improvement then try a 3. If little improvement leave it at 2. Yours being an oldie may not even have the hardened connecting rods so be conservative
Mon Oct 12, 2020 9:05 pm
Thanks, Will. I installed new conn rods were new when I split the case.
Appreciate the info, bud!
Mon Oct 12, 2020 11:53 pm
