It is currently Mon Dec 08, 2025 10:34 pm
Reply to topic  [ 9 posts ]
 New casing bolts?
Post New casing bolts?
I'm running a Briggs 32. 2 years ago I replaced the casing bolts with 3/8-16 Grade 8 bolts. Two have snapped off near the starboard head. Should I go with a stronger bolt, or a weaker one (less brittle, more stretch? Is that a thing?) If I go with a stronger bolt, will that cause the casing to crack? Thought I had this fix nailed, but 2 bolts next to each other failing makes me think I was sure wrong.
Help?
32 PD with EVT cam, decked heads, shaved pistons and not enough sense to leave things alone!
Mon Oct 12, 2020 12:43 pm
Post Re: New casing bolts?
Still had a dry gasket setup?
Mon Oct 12, 2020 8:47 pm
Mon Oct 12, 2020 11:55 pm
Use a gasket sealant instead.
Tue Oct 13, 2020 7:03 am
Tue Oct 13, 2020 10:09 am
I reinstalled the factory case gasket when I reassembled.
I like the idea of eliminating the gasket, but with the season around the corner I may wait until I do some post season mods. Would really appreciate any detailed info available so I can figure out what to do.
Tue Oct 13, 2020 11:15 am
Converting to a wet gasket strengthens the block and should solve your issues
Tue Oct 13, 2020 11:39 am
Tue Oct 13, 2020 12:12 pm
Users browsing this forum: BPD528 and 1 guest
