It is currently Tue Mar 17, 2026 2:15 am
Reply to topic  [ 7 posts ]
 Corrosion control
New Member
Post Corrosion control
Do you guys spray your motors down with something before you get it in salt water? If so what do you use? Trying to keep the corrosion down although there’s already quite a bit on the block .
Thank you
Thu Dec 24, 2020 3:23 pm
Post Re: Corrosion control
Check this thread out:
viewtopic.php?f=4&t=52716
Thu Dec 24, 2020 5:40 pm
I hunt 95% in salt water. Have had my 4400HDR since 2017. I spray it down every time when I get back, and then after it is
dried I have a mixture of 1/3 motor oil and 2/3 WD-40 in a spray bottle and spray her down and wipe. The oil helps lube and keeps
the WD-40 on... Motor still looks brand new
Lead, Follow or Get The Hell Out Of The Way!!!!
1754 Gator Trax Hybrid, Hunt Deck ,with MB 4400 Black Death HDR, Duck Slaying, Mud Slingin Machine!!!
Fri Jan 01, 2021 9:48 am
Profile YIM
The oil helps lube what? I get that it assists with corrosion prevention, but there isn't anything on the external of the engine or frame that needs lubrication. It's all handled by engine oil or grease into an alemite/zerk.
#mudmotor>physics
Fri Jan 01, 2021 10:06 am
Fri Jan 01, 2021 1:54 pm
Living on the Gulf in Alabama i wash down after every trip and use a product called INOX it works very good but is hard to find Sid Thysen at Fast Duck motors sells it 386 747 7652I spray it into the fan while its running also every bolt on my 4400 BD has al. never sieze the WD 40 and oil will work too Says Ronbow
Gator Trax 16/50 ---HDR Black Death 4500 BPS SWAMP STAFF
Fri Jan 01, 2021 2:41 pm
you are correct it doesn't LUBE anything on the outside... misspoke,,, I meant you can use it as LUBE to hit your springs on the carb
shoot some down the throttle cable, shit like that
Sat Feb 06, 2021 8:46 am
Profile YIM
