It is currently Sat Jul 05, 2025 2:42 pm
Reply to topic  [ 43 posts ]  Go to page 1, 2  Next
 evt pistons
Post evt pistons
can you use stock rods with the evt pistons (standard bore flat tops)
Wed Jul 27, 2011 5:40 pm
Post evt pistons
As long as the wrist pin diameter is the same. Get with mike or silk to verify.
Wed Jul 27, 2011 5:45 pm
Post Re: evt pistons
ight do you know how much compression i could expect with those pistons and .60 heads
Wed Jul 27, 2011 5:47 pm
Prolly too much! lol
Are you shaving the stock pistons or purchasing an aftermarket flat top? If shaving the stockers, I believe you'll want the longer rods.
If your going through all that work, why not go big bore? I have a feeling craig could steer you in the right direction if you want to go that route. I think you'd want to go back to stock heads though.
Wed Jul 27, 2011 5:48 pm
i have a friend that is going to give me the flat tops for free
Wed Jul 27, 2011 5:49 pm
Post evt pistons
Wed Jul 27, 2011 5:51 pm
Wed Jul 27, 2011 5:56 pm
the pistons came with evt rods stock length
Wed Jul 27, 2011 6:01 pm
Post evt pistons
Wed Jul 27, 2011 6:12 pm
thanks craig
Wed Jul 27, 2011 6:24 pm
also have access to dual carbs whats yalls thought on them
Wed Jul 27, 2011 6:25 pm
Post evt pistons
Wed Jul 27, 2011 6:38 pm
Post evt pistons
What do you have now!!
17x48 extreme stage 2 GTR
Wed Jul 27, 2011 6:46 pm
I have a stage 1 with stock carb but this is going to be a semi play motor
Wed Jul 27, 2011 6:49 pm
i got a set of extended length evt rods for sale
Wed Jul 27, 2011 6:53 pm
Don't think they'll work for my application
Wed Jul 27, 2011 7:33 pm
Post evt pistons
Wed Jul 27, 2011 7:34 pm
so what do you recommend i have the stage one for reliability but i want something with a little more with semi reliability
Wed Jul 27, 2011 7:51 pm
Post evt pistons
Is your timing advanced!! Bro if I was you I would stay with the stock pistons
Wed Jul 27, 2011 9:12 pm
why you say stay with the stock pistons
Wed Jul 27, 2011 9:18 pm
so i have the mikuni in the shed what else could i do to give it more pep. it will have cam heads exhaust and mikuni
Wed Jul 27, 2011 9:22 pm
Wed Jul 27, 2011 9:27 pm
what does a stage 2 have?
Wed Jul 27, 2011 9:32 pm
Wed Jul 27, 2011 9:44 pm
but they are flat tops which gives you more compression right?
Wed Jul 27, 2011 9:55 pm
Wed Jul 27, 2011 10:26 pm
i was under the impressin that these pistons were flat tops and the rist pins were raised ie giving it more compression
Wed Jul 27, 2011 10:28 pm
Thu Jul 28, 2011 3:12 am
i think im just going to let someone look at wha ive got and go from there. just need that a little more ya know.......thats what she said lol
Thu Jul 28, 2011 8:50 am
You will be over 200 psi on compression with those pistons. Deck height was raised with those pistons along with removing the dish. Fastest motor I built had those pistons with .030" decked heads. 1854 GTB ran 40.6 mph.
Thu Jul 28, 2011 9:29 am
so in other words it probably wont last to long with heads shaved .050
Thu Jul 28, 2011 10:59 am
Don't run every where at 5 grand and it may last a little while.
Thu Jul 28, 2011 8:05 pm
I'm just confused I have a stage one but want more and anything more is going to blow up. There must be something that will give you more and will be half ass "safe"
Thu Jul 28, 2011 8:43 pm
Post evt pistons
It's a money game !! Pay to play
Thu Jul 28, 2011 8:53 pm
Thu Jul 28, 2011 9:29 pm
I understand you have to pay to play but Im not going to waste my money on something I know for a fact will blow up in ten hours
Thu Jul 28, 2011 9:54 pm
I've put money on worst odds
Fri Jul 29, 2011 4:52 am
Post evt pistons
Their is enough research that can be done on this site !! Your money !!
Fri Jul 29, 2011 5:38 am
Look at a race car motor. They make bIG power, but they either blow em up once in a while or tear em down after a few races and then fix stuff before it blows. Regardless its alot of coin to play with.
Fri Jul 29, 2011 6:17 am
What are you looking to do? Carry more weight or go fast? You want more speed then build a boat and prop for the motor you have.
Fri Jul 29, 2011 10:57 am
Users browsing this forum: No registered users and 119 guests
