It is currently Wed Jul 09, 2025 11:16 am
Reply to topic  [ 44 posts ]  Go to page 1, 2  Next
 Battery
Post Battery
For a 36 PD could a larger motorcycle battery be used to start the motor? I was wondering cause it's alot less weight to carry than a standard deep cycle marine battery.
Sun Aug 21, 2011 12:00 am
Post Re: Battery
get a stinger
Sun Aug 21, 2011 12:05 am
Post Re: Battery
It would make a great back up, other than that I wouldn't trust it.
Sun Aug 21, 2011 10:43 am
Post Re: Battery
I am trying to decide what size batteries I need as well. Trying to go as light a possible without breaking the bank. Probably going with Deka brand.
One will be for engine, bilge, and running lights.
The other will be for stereo, swamp lights, winch.
Sun Aug 21, 2011 3:26 pm
Post Battery
I run the smallest car battery Walmart has, have had no issues
17x48 extreme stage 2 GTR
Sun Aug 21, 2011 3:29 pm
Post Re: Battery
Sun Aug 21, 2011 6:26 pm
Post Re: Battery
Thanks guys....Appreciate the input.
Sun Aug 21, 2011 9:03 pm
Post Re: Battery
I've run Sam's club garden tractor batteries for years with no problems. On long trips I do take a spare battery because I'm old and forgetful. If you leave a key or bilge pump on overnight it won't matter much what size your main battery is and you will be happy you have a spare. I also carry a cheap set of jumper cables in my "possibles" box. So far I've only needed them to start others, but my chance is coming.
Mon Aug 22, 2011 10:48 am
Post Re: Battery
Mon Aug 22, 2011 11:30 am
Post Re: Battery
Different charging systems.
Mon Aug 22, 2011 11:34 am
Post Re: Battery
O, can you tell me what the difference is? I'm curious now...
Is it that the motorcyle recovers the charge at a faster rate?
Mon Aug 22, 2011 11:46 am
Post Re: Battery
I'm not familiar with the charging system on a bike, but know for certain it is different than the one we have on our engines. The cdi motors have a decent charging system 20a at idle on up to 50a at full output. The older engines have no output at idle and I think around 20a at full output. I believe the stator on a bike is inside the block, where ours is mounted outside under the flywheel, but I am not familiar with their output ratings.
Mon Aug 22, 2011 11:52 am
Post Battery
The clutch alone draws 20 amps!! So if your idling alot and using trim auto reverse it can draw a battery!!
Mon Aug 22, 2011 11:54 am
Post Re: Battery
Mon Aug 22, 2011 11:57 am
Post Battery
If I remember right Hoyt told me that but I could be wrong.
Mon Aug 22, 2011 11:59 am
Post Re: Battery
I'd go put a meter on mine, but don't really want to now. Over 10amps will pop my meter. lol I've been told somewhere in the 4-10 range. 20amps is a pretty hefty draw.
Mon Aug 22, 2011 12:03 pm
Post Re: Battery
Actually I think the charging systems on a H-D are very simular to that of a MM V-Twin. This article explains the H-D charging system. http://www.harleyhowto.com/forum/showthread.php?t=338
I do however think that the H-D charging system may have a higher amperage output than that on a MM. I just put a new battery on my Fatboy and you would be amazed at the price. $87 and that was the cheapest one I could find. One from Harley is around $125+ so I'm not sure that there is any cost savings going with a motorcycle battery, weight savings yes.
Russ
Mon Aug 22, 2011 12:30 pm
Post Re: Battery
The compression on alot of custom harleys is way more than a MM. My friend has a BMW touring bike and that thing has everything imaginable on it.....sat radio, cd player, air suspension, ect, so I figured it might work on a MM.
Mon Aug 22, 2011 4:48 pm
Post Battery
It is 20 amps.
Mon Aug 22, 2011 4:55 pm
Post Re: Battery
Mon Aug 22, 2011 5:17 pm
Post Re: Battery
Would a smaller battery have enough power to turn the motor over.
Mon Aug 22, 2011 5:47 pm
Post Re: Battery
Mon Aug 22, 2011 5:52 pm
Post Re: Battery
18x48 Charles Leonard / 36PD
Mon Aug 22, 2011 6:02 pm
Post Re: Battery
So it sounds like I should get a small auto starting battery for the motor and a small deep cycle for the accessories?
Mon Aug 22, 2011 8:23 pm
Post Re: Battery
Tue Aug 23, 2011 4:17 am
Post Re: Battery
Tue Aug 23, 2011 5:21 am
Post Battery
I text Hoyt to make sure that is what he told me !! 20 amps
Tue Aug 23, 2011 5:30 am
Post Re: Battery
http://www.messicks.com/Articles/Fixing ... lutch.aspx
Second paragraph. Seems like they draw aboout 3.5 amps ISh
Tue Aug 23, 2011 5:39 am
Post Re: Battery
http://www.ganos.com/electricclutchtesting.pdf
Another link, this one is showing about 4 amps of current draw.
Tue Aug 23, 2011 5:50 am
Post Re: Battery
Tue Aug 23, 2011 7:15 am
Post Re: Battery
GD's don't have those clutch drainin the battery problems at all..........jus sayin :mrgreen:
Just a displaced hillbilly in Cajunland
Beavertail Predator LT/17' alum vee total mismatch but ya use what ya gots
Tue Aug 23, 2011 8:43 pm
Post Re: Battery
23 MB mini w/ IM heads, BPS rockers/rods and gutted exhaust on a rivited 1648 crestliner.
Wed Aug 24, 2011 8:43 am
Post Re: Battery
I have two batteries. I keep a small lawn mower battery in the bow for a backup.
My engine burned a plug and quit charging my battery and eventually drained it. I was lucky because I was very close to my camp.
the day before I was in lillies two feet high about two miles from the nearest bayou and almost turned my motor off several times while scouting for ducks, glad I didn't- I would have been like chuck!
always bring a spare.
Wed Aug 24, 2011 1:58 pm
Post Re: Battery
Thanks for the input guys
Wed Aug 24, 2011 10:06 pm
Post Re: Battery
i have a deep cycle battery thats the size of a tractor battery. might be something to look into
Thu Aug 25, 2011 4:54 pm
Post Re: Battery
I'm running a Group 24 hybrid marine Deep Cell/ Cranking battery from auto zone that's been great. I've had a set for 3 years in my offshore boat that are still perfect.
Thu Sep 01, 2011 10:40 pm
Post Re: Battery
Get yourself a Optima ;)
Fri Sep 02, 2011 6:15 am
Post Re: Battery
Fri Sep 02, 2011 6:17 am
Post Re: Battery
Fri Sep 02, 2011 5:43 pm
Post Re: Battery
Fri Sep 02, 2011 7:36 pm
Users browsing this forum: No registered users and 89 guests
