It is currently Fri Jul 18, 2025 2:34 pm
Reply to topic  [ 79 posts ]  Go to page 1, 2  Next
 35 gator tail motor making noise
Post 35 gator tail motor making noise
my motor not running full speed making noise like rattching click
can't tell if it is valve stuck
w :cry:
Sun Sep 30, 2012 12:28 pm
Post Re: 35 gator tail motor making noise
know of any good mechanic broussard area work on 35 briggs
thanks will ford
Sun Sep 30, 2012 12:36 pm
Try removing one spark plug at a time to see which side is the
good side - you may have a dead cylinder - ie ignition or valve
It will die when you remove the good side plug wire
Sun Sep 30, 2012 12:38 pm
I say bent or broken pushrods,open valve covers to check.
Sun Sep 30, 2012 1:36 pm
Unless if the clicking you hear is a plugwire arching on the side of the engine.....crank it up and pee on each side of it,the side that cuts you for a flip is the bad side.
Sun Sep 30, 2012 1:41 pm
Sun Sep 30, 2012 2:07 pm
35 GTR - 1754 Extreme
Sun Sep 30, 2012 3:06 pm
1752 Uncle J, Calen Stage 1 35 GTR
Mon Oct 01, 2012 8:24 pm
hey curltail,if it happens to you,dont worry....i heard today that:
Pfizer Corp. announced today that Viagra will soon be available in liquid form, and will be marketed by Pepsi Cola as a power beverage suitable for use as a mixer.
It will now be possible for a man to literally pour himself a stiff one. Obviously we can no longer call this a soft drink, and it gives new meaning to the names of "cocktails", "highballs" and just a good old-fashioned "stiff drink". Pepsi will market the new concoction by the name of:
MOUNT & DO.
Thought for the day: There is more money being spent on breast implants and Viagra today than on Alzheimer's research.
This means that by 2040, there should be a large elderly population with perky boobs and huge erections and absolutely no recollection of what to do with them.
Mon Oct 01, 2012 9:57 pm
16.5' x 46" Instagator w/25GTRRRR
SetxPerformanceshop.com or (409)548-4477
Tue Oct 02, 2012 6:08 am
lmao :lol:
Tue Oct 02, 2012 6:54 am
This thread took a turn.
Tue Oct 02, 2012 7:05 am
Tue Oct 02, 2012 11:07 am
it is a connecting rod broke
might order new engine on line what size shaft does a 35 with reverse have :( :( :(
thanks for the suggestions
it mashed the right plug hard to pull out
Sat Oct 06, 2012 5:49 pm
Sat Oct 06, 2012 5:56 pm
Thanks the Mechanic pulled the plug off before me and told me it is a connecting rod
i think you are Right CB
i am going to pick it up and check it my self i have a little experience wit motors and some common scence
Thanks
Sat Oct 06, 2012 6:10 pm
I hope you didn't pay for that diagnosis if all he did was remove a spark plug.
Sat Oct 06, 2012 6:30 pm
Sat Oct 06, 2012 6:51 pm
If this is the engine that's at my shop yes I pulled a spark plug and called a broke connecting rod! YES it is broken its not just a rattle or noise, it is knocking very bad and about to come apart. The spark plug wasn't simply "bent" it was destroyed and I barley got it out I the head. And I would like to think I may know what a broken connecting rod sounds like when I hear one. Not everyone needs to disassembled to tell if a rod is broken!
Calen's Engine Service
337-578-4434
Sat Oct 06, 2012 6:58 pm
No chit, must have esp or xray vision or something...
Maybe he called Mrs Cleo last night... :-?
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Oct 06, 2012 6:59 pm
I didn't even have to pull the spark plug to tell on my 2 lol
17x48 extreme stage 2 GTR
Sat Oct 06, 2012 7:09 pm
smart money is on calen.
Sat Oct 06, 2012 7:16 pm
Sat Oct 06, 2012 7:17 pm
Sat Oct 06, 2012 7:18 pm
Sat Oct 06, 2012 7:19 pm
not to change the subject but i've been cutting beans in the field tonite. what was the score of the Lspee-u - florida game. :lol:
Sat Oct 06, 2012 7:25 pm
Sat Oct 06, 2012 7:31 pm
Don't know that yet haven't taken it apart
337-578-4434
Sat Oct 06, 2012 7:44 pm
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Oct 06, 2012 8:39 pm
yep,now you can REALLY take my advice.....stand on the huntdeck and piss on it,its fukked.lol.
Sat Oct 06, 2012 8:50 pm
Sun Oct 07, 2012 12:45 am
Well this is true.on a engine not running but when a engine is turning 4000 RPMS alot of times if the rod breaks and gets high enough out of the way of the crank to where it doesn't come thru the side it usually mets the valves which usually break when they hit each other It's funny how alot of you are saying what can happen, what can't happen, how to trouble shoot, what's not broken what is broken and. Not one of you have seen or heard this thing run. Tell you what I have a deal for you 50hp or anyone else who wants to take it IF the rod on the #2 cylinder is NOT broken I will replace the engine or repair it for free! If the rod IS broken you pay for a replacement engine. Do I have any takers?? really funny how some one can say rattle or tapping. And all of you know what it is or isn't!!
337-578-4434
As I was writing the customer information down I looked at the motor for about 2 minutes all I DO know is it has a broken rod. Yeah of coarse there is more damage but I will not know the extent of damage untill I take it apart.
337-578-4434
Sun Oct 07, 2012 1:04 am
He THINKS it has heads and cam. I didn't build it so I don't know any of the specs
337-578-4434
Sun Oct 07, 2012 1:06 am
If Calen told me my engine wasn't running right cause there was a Keebler elf stuck in the crankcase, I'd tell him to fix it and send me the bill.
1854 Sportsman's Fab
2046 Uncle-J Skiff
35 GTR
Sun Oct 07, 2012 2:13 am
Hey watch it with the elf jokes! Its almost christmas but got damn. I hope the motor gets fixed
Sun Oct 07, 2012 4:40 am
2046 Uncle-J Skiff
35 GTR
Sun Oct 07, 2012 6:27 am
Who gives a fuck !! Dude has a broke motor. It's almost hunting season I'm sure Calen or who ever Fixes that all he worried about
Sun Oct 07, 2012 7:13 am
Go get back under your rock, ain't no body pulled your cord....YOu speak when i tell you too puppet
Sun Oct 07, 2012 7:49 am
Users browsing this forum: Google [Bot] and 146 guests
