It is currently Thu Jul 17, 2025 10:34 pm
Fletch
 Re: Dual exhaust cracked
Not sure which flat piece your talking about.
Thu Sep 20, 2012 2:30 am |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
The flat part that that has the pipe sticking out of it.
_________________ 1850 & 36pd
Thu Sep 20, 2012 3:52 am |
11Bravo
My experience with duals. My last MM was a long tail GD with a 27 hp Kohler. I run 100% of the time in salt water and that first muffler didn't last long. I'm a welder and fabricator for 40+ years and made my own set of duals using 316 16 ga. and stuck 3" Supertrapp cans on the header pipes. My single support tube did crack and after changing out the support tube to one larger no more cracks. What did happen was the engine vibration loosened the end nut on the baffle end cap and lost those guts to 30' of water, safety wire was the answer to that one. The duals looked great on the long tail but on my 36 PD this winter I will build something different which I've been kicking around.
Thu Sep 20, 2012 12:53 pm |
SmokeEater829
Joined: Sat Jun 13, 2009 8:48 pm Posts: 1830 Location: Belle Chasse, LA
Well, here is an update. Got the boat home today and looked closer at the pipes. On the side with the crack, the baffle in the end of the pipe is loose and just jiggling around. On the other pipe, there is no crack and the baffle in the end is tight, the welds are still holding. But, I can turn the whole pipe! Where the smaller diameter pipe slips into the larger muffler portion is loose. The other side does not do this. I'm guessing, and I'm definitely not a mechanic, that this pipe not being firmly attached may be what's causing that side to run so hot? Possibly more air getting into that muffler causing the flame that I saw the other night? Could that be the case or am I totally off track?
_________________ Mud Buddy 4500 Black Death hauling the Uncle J 18x58
Thu Sep 20, 2012 2:45 pm |
Users browsing this forum: Google [Bot] and 105 guests |
