Re: 25 HP Kohler GD LT Not running right
Your carb might be all varnished up from sitting so long. Make sure your getting fuel to the carb, if you are make sure the float isnt sticking closed and not letting fuel in. You can try tapping on the float bowl to get the float to drop but if that doesnt do it you will have to pull the carb apart and clean it. I'd start with this
