It is currently Fri Jun 27, 2025 8:26 pm
Reply to topic  [ 18 posts ]
 Possible Oil Leak
Post Possible Oil Leak
Starting to see an oil leak on the filter side of the GT where the rear case cover bolts to the block. Only on the filter side, not anywhere else. Any thoughts?
Ace
Cajun Performance 1854/GTR35 Tiller (Lil Daddy Mods)
Sun Jun 13, 2010 8:14 am
Post Re: Possible Oil Leak
that's where they always leak, right there at the oil galley. If you'll notice there's 11 bolts. 6 on the other side, and 5 on the oil galley side. Piss poor design... putting the oil galley right where the 12th bolt should've gone. They should have incorporated a bolt in there somehow.
You may be able to slow it down some by tightening the bolts a little, but be careful... you could crack the sump. You won't stop it, it'll have to be changed sooner or later. It don't hurt to run it... I run mine until they're pukin oil then I finally break down and change it. lol
good luck.
Sun Jun 13, 2010 8:49 am
Ace
Sun Jun 13, 2010 9:14 am
Thats where mine was leaking, Brought it to GT they slapped a new gasket on it. Lemme guess right by the serial numbers where you can see the gasket really well. Def your case gasket. How many housrs since it was taken apart Howard? Mine was just a seep and keeping the side of the block wet, Hope the new style gasket helps.
Mon Jun 14, 2010 8:13 am
keep a couple of quarts in your boat for security reasons! it took me 2 1/2 quarts to get across flat lake one afternoon.
Mon Jun 14, 2010 9:33 am
Mon Jun 14, 2010 9:38 am
Ace
Mon Jun 14, 2010 11:30 am
Ace
Mon Jun 14, 2010 11:31 am
Hey Ace i have the same thing, i have 75hrs. on mine and i noticed that it wasleaking this weekend at Caddo, it is barely coming out, i checked my oil and it was fine! :)
I jjust don't want to drive 2 hrs. for them to do the gasket, i am a long way i guess when it gets real bad i'll bring it to them! ;)
Mon Jun 14, 2010 11:34 am
Ace
Mon Jun 14, 2010 11:37 am
Mon Jun 14, 2010 11:55 am
Thats why I sent mine. Mine was never a gusher... and doubtful it would have ever been one. No different than a leaky valve cover on a vehicle. It is more of an annoyance than a real problem. These engine dont quite have a balanced rotating assembly.
Mon Jun 14, 2010 12:23 pm
Mon Jun 14, 2010 1:52 pm
Mon Jun 14, 2010 2:11 pm
Mon Jun 14, 2010 2:13 pm
Had gasket changed twice.The third time a had a local briggs repair shop fix for good. They ar aware of situation.There is a flaw in the recessed ports being not deep enough.The new cover which i have is recessed deeper and thicker "o" ring gasket.No problem since. Might want to make a callto Theriot's in westwego,LA for more assistance.
Sat Jun 26, 2010 4:12 pm
Turbodrive let her go for 200 hours puking oil and it cost him a new cover. It closed up the clearance on the cam and tried to weld the cam to the cover. Cam was salvagable but the cover was not.
Sat Jun 26, 2010 9:44 pm
Sat Jun 26, 2010 10:30 pm
Users browsing this forum: No registered users and 155 guests
