Ace
Joined: Thu Jan 15, 2009 9:26 am Posts: 285 Location: Lafayette LA
 Possible Oil Leak
Starting to see an oil leak on the filter side of the GT where the rear case cover bolts to the block. Only on the filter side, not anywhere else. Any thoughts?
_________________ Ace Cajun Performance 1854/GTR35 Tiller (Lil Daddy Mods)
Sun Jun 13, 2010 8:14 am |
stumpgrinder
 Re: Possible Oil Leak
that's where they always leak, right there at the oil galley. If you'll notice there's 11 bolts. 6 on the other side, and 5 on the oil galley side. Piss poor design... putting the oil galley right where the 12th bolt should've gone. They should have incorporated a bolt in there somehow.
You may be able to slow it down some by tightening the bolts a little, but be careful... you could crack the sump. You won't stop it, it'll have to be changed sooner or later. It don't hurt to run it... I run mine until they're pukin oil then I finally break down and change it. lol
good luck.
_________________ I'm your Huckleberry......... http://www.youtube.com/watch?v=XqVe3xG-wos
I am proud to be an American, I am glad that I am free... but right now I wish I was a dog, and Obama was a tree.
Sun Jun 13, 2010 8:49 am |
Ace
Sun Jun 13, 2010 9:14 am |
MaXXis85
Thats where mine was leaking, Brought it to GT they slapped a new gasket on it. Lemme guess right by the serial numbers where you can see the gasket really well. Def your case gasket. How many housrs since it was taken apart Howard? Mine was just a seep and keeping the side of the block wet, Hope the new style gasket helps.
Mon Jun 14, 2010 8:13 am |
coondik
keep a couple of quarts in your boat for security reasons! it took me 2 1/2 quarts to get across flat lake one afternoon.
Mon Jun 14, 2010 9:33 am |
UNCLE-J
Joined: Fri Jul 24, 2009 7:26 am Posts: 10388 Location: S-Ville, LA
Mon Jun 14, 2010 9:38 am |
Ace
Mon Jun 14, 2010 11:30 am |
Ace
Mon Jun 14, 2010 11:31 am |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
Hey Ace i have the same thing, i have 75hrs. on mine and i noticed that it wasleaking this weekend at Caddo, it is barely coming out, i checked my oil and it was fine! I jjust don't want to drive 2 hrs. for them to do the gasket, i am a long way i guess when it gets real bad i'll bring it to them!
Mon Jun 14, 2010 11:34 am |
Ace
Mon Jun 14, 2010 11:37 am |
stumpgrinder
Mon Jun 14, 2010 11:55 am |
MaXXis85
Thats why I sent mine. Mine was never a gusher... and doubtful it would have ever been one. No different than a leaky valve cover on a vehicle. It is more of an annoyance than a real problem. These engine dont quite have a balanced rotating assembly.
Mon Jun 14, 2010 12:23 pm |
take'emgator
Mon Jun 14, 2010 1:52 pm |
quackconsumer
Mon Jun 14, 2010 2:11 pm |
take'emgator
Mon Jun 14, 2010 2:13 pm |
kdog123
Joined: Wed Mar 31, 2010 4:14 am Posts: 38 Location: Meraux,LA
Had gasket changed twice.The third time a had a local briggs repair shop fix for good. They ar aware of situation.There is a flaw in the recessed ports being not deep enough.The new cover which i have is recessed deeper and thicker "o" ring gasket.No problem since. Might want to make a callto Theriot's in westwego,LA for more assistance.
Sat Jun 26, 2010 4:12 pm |
drake1
Turbodrive let her go for 200 hours puking oil and it cost him a new cover. It closed up the clearance on the cam and tried to weld the cam to the cover. Cam was salvagable but the cover was not.
Sat Jun 26, 2010 9:44 pm |
TURBODRIVE
Sat Jun 26, 2010 10:30 pm |
