ENGINES BLOWING UP .. Story Time..... http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=10380 |
Page 1 of 2 |
Author: | UNCLE-J [ Mon Jun 21, 2010 8:47 am ] |
Post subject: | ENGINES BLOWING UP .. Story Time..... |
There is a bunch of talk about whos mods are more dependable. Lets here some stories of Blown up Engines !!!! (this should be fun) |
Author: | Josh [ Mon Jun 21, 2010 11:48 am ] |
Post subject: | Re: ENGINES BLOWING UP .. Story Time..... |
my truck blew a head gasket at 19,000... |
Author: | UNCLE-J [ Mon Jun 21, 2010 11:49 am ] |
Author: | indybill [ Mon Jun 21, 2010 12:07 pm ] |
first MM I had was a briggs 16 hp lt. blew a head gasket. other than that ran great. 15 years ago. |
Author: | Brinkleydog [ Mon Jun 21, 2010 1:00 pm ] |
Crack block.......flaten a cam...broke 20 case bolts....all in less than 10 hours adn 2 rebuilds....but it was the motor not the mods ![]() ![]() ![]() |
Author: | slambin [ Mon Jun 21, 2010 1:26 pm ] |
one day i found out that a 27 kohler lt will not run without a muffler. but it will run with 3 holes in the muffler and the oil full of water. |
Author: | mcnemar1982 [ Mon Jun 21, 2010 1:38 pm ] |
Chime in Deltaduck |
Author: | dog walker [ Mon Jun 21, 2010 2:53 pm ] |
cracked blocks are bad OK,modded motors are the devil. |
Author: | UNCLE-J [ Mon Jun 21, 2010 3:29 pm ] |
I want to here of a Stage 1,2,or 3 blowing.. And what reason it blew. |
Author: | Brinkleydog [ Mon Jun 21, 2010 3:35 pm ] |
mine was a stage 1 for 80 or so hrs and a stage 2 for less than 10. |
Author: | UNCLE-J [ Mon Jun 21, 2010 3:36 pm ] |
Author: | coondik [ Mon Jun 21, 2010 3:43 pm ] |
you ain't lived, until you've seen a 8V71 run away and tear itself apart! |
Author: | Brinkleydog [ Mon Jun 21, 2010 4:05 pm ] |
Author: | JIMMY W [ Mon Jun 21, 2010 5:06 pm ] |
Dependable Mods??? No Such Thing!!!!!! ![]() |
Author: | bjg [ Mon Jun 21, 2010 6:48 pm ] |
Author: | Gator Guy [ Mon Jun 21, 2010 7:11 pm ] |
Mine went VROOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOM........ clink.... CLINK... CLUNK!!!!!!!! that pretty much explains it. |
Author: | bjg [ Mon Jun 21, 2010 7:19 pm ] |
Author: | bayouboy [ Mon Jun 21, 2010 8:16 pm ] |
Best I've got to add on the topic is a cracked oil sump and some knocking. It still ran decent, but it got to the point where I couldn't tell if the rainbow in my roostertail was from the sun or the sump! LOL |
Author: | deltaduckmaster [ Mon Jun 21, 2010 8:17 pm ] |
Author: | cb5331 [ Mon Jun 21, 2010 8:20 pm ] |
Author: | OwenDickeson [ Mon Jun 21, 2010 8:23 pm ] |
Author: | brlcla [ Mon Jun 21, 2010 8:42 pm ] |
Author: | Mitschke [ Mon Jun 21, 2010 10:08 pm ] |
Author: | deltaduckmaster [ Tue Jun 22, 2010 5:04 am ] |
That is my old motor!! My new onw well its old now will be around for a long time!! I had a hole in the boot to my carb that leand out the cylinder |
Author: | drake1 [ Tue Jun 22, 2010 5:34 am ] |
LEAN!! That combustion chamber and piston show different. ![]() |
Author: | shallow water master [ Tue Jun 22, 2010 6:10 am ] |
Author: | drake1 [ Tue Jun 22, 2010 6:29 am ] |
That gorge you see in the middle of the piston is not a hole that was burned into it from being lean more like detonation and the connecting rod being shoved through it from more than likely being siezed in the cylinder from overheating. That is not a Briggs piston that I see there, looks more like a Generac piston which is alot bigger. ![]() |
Author: | chops3131 [ Tue Jun 22, 2010 11:49 am ] |
Author: | indybill [ Tue Jun 22, 2010 3:31 pm ] |
Either way I think he wins!!!! One big bomb. |
Author: | DeathMetalDukk [ Tue Jun 22, 2010 4:04 pm ] |
Maybe Radikkle will chime in, he's got a story ![]() |
Author: | aucoin [ Tue Jun 22, 2010 7:14 pm ] |
15 hrs...was still running hard...started smelling oil burning with alot of smoke, killed the engine, then the click, clack, pop , tink was the crack finding it self around the whole block. absolutely no internal parts damaged.....proir to that, i had 8 bolts break on 3 different outings, this motor was a stage 3+ built by evt...but i can say was a massive beast while it was running....got 42.7mph our of it on a 1748 skiff and pulled like a 90 merc out the hole |
Author: | OwenDickeson [ Tue Jun 22, 2010 7:51 pm ] |
Author: | radikkle [ Tue Jun 22, 2010 8:37 pm ] |
I got 16 hours out of my stage 3, broke cam,stud pulled out of the head and left 2 inch hole,5 crank case gaskets,several bolts that fell out or broke off in block,and a cracked crank case.this all happend around 3500-3700 rpm. |
Author: | UNCLE-J [ Tue Jun 22, 2010 9:01 pm ] |
Were did the parts come from on that stage 3? |
Author: | radikkle [ Tue Jun 22, 2010 9:07 pm ] |
EVT. |
Author: | chops3131 [ Tue Jun 22, 2010 9:56 pm ] |
Author: | DeathMetalDukk [ Tue Jun 22, 2010 10:02 pm ] |
Author: | UNCLE-J [ Tue Jun 22, 2010 10:12 pm ] |
Was there any warranty? If not, WHY? |
Author: | deltaduckmaster [ Tue Jun 22, 2010 10:18 pm ] |
The motor ran fine until that never had a nock or noise come out of it!! Either the hole came from comming across the lake with the carb weight pulling down on it with the rough water!! OOOOOrrr the other thing waas the connecting rod bolt broke!! |
Author: | BROOKS [ Wed Jun 23, 2010 8:00 am ] |
This is all kind of interestin' but I gots a querston that has came up 'round our camp a couple different times ..... Please do note that I ain't tryin' to put a stir in the pot !!!!! Has anyone's had a souped-up MudBuddy that was built by MudBuddy to come unraveled ?? |
Page 1 of 2 | All times are UTC - 6 hours |
