Tell me about the new CDI from Vanguard...........
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=10572
Author:  bbb [ Wed Jun 30, 2010 8:30 am ]
Post subject:  Tell me about the new CDI from Vanguard...........
........since I just bought one and didn't even know it.
Since it has a rev limiter of 4300, is there not a governor anymore?
Is there any reason to double up the throttle/governor spring or put the small spring on there? My motor is running around 3600 with a load. Out of the water its pushing the 4300 mark, probably around 4200.
Anything else I should know about it that is different from the old big blocks?
Author:  MaXXis85 [ Wed Jun 30, 2010 8:37 am ]
Post subject:  Re: Tell me about the new CDI from Vanguard...........
It has a better charging system, Satinless muffler, lighter flywheel (some dislike)
Author:  POKER1 [ Wed Jun 30, 2010 9:36 am ]
Burns alot more gas for some reason.
Author:  deadbird8 [ Wed Jun 30, 2010 12:15 pm ]
Its got potted coils which perform timing advance as the RPM increases, coated hardware, better electrical, gets rid of the anti-backfire solenoid, better fuel pump (runs off vacuum from intake vs. the cam). Maybe the timing advance burns more fuel- I haven't noticed that.
All the governor linkage and gear are still there even though the electronic rev limiter is built into the coils (its a more graceful rev limit than the external boxes too). I think it has to do with the linkage requiring the governor arm (re-used from the regular vanguard).
You are running a really heavy load to only have 3600 in the water. If you have the foam pre-filter on your air filter, take it off and let that motor breath some.
Author:  bbb [ Wed Jun 30, 2010 12:31 pm ]
Author:  POKER1 [ Wed Jun 30, 2010 3:00 pm ]
At caddo we made a short run Friday morning and then a run up over to Jefferson (26 miles one way). Don had burned 6 gal at that point. I didn't burn 6 gal the entire day. That's a good deal more fuel.
Author:  cb5331 [ Wed Jun 30, 2010 4:00 pm ]
You ran all the way to jefferson and back on less than 6 gallons? Damn. My 27 makes it with about five gallons, and my dads 32 takes right at 6 just to get there.
Author:  jus10inla [ Wed Jun 30, 2010 4:11 pm ]
ronnie.. u mean don (duckhunter888)? he doesnt have a CDI motor...
Author:  POKER1 [ Wed Jun 30, 2010 4:56 pm ]
Author:  duckhunter888 [ Wed Jun 30, 2010 5:02 pm ]
Author:  POKER1 [ Wed Jun 30, 2010 5:08 pm ]
Author:  POKER1 [ Wed Jun 30, 2010 5:10 pm ]
Author:  jus10inla [ Wed Jun 30, 2010 7:04 pm ]
Author:  LA Mudder [ Wed Jun 30, 2010 8:03 pm ]
I dont know about yoll but mines dont want to start as easy as my gdsd that i used to have
Author:  deadbird8 [ Wed Jun 30, 2010 10:42 pm ]
Author:  jus10inla [ Wed Jun 30, 2010 11:20 pm ]
Yea kyle was runnin one for a while
Author:  Brinkleydog [ Thu Jul 01, 2010 7:29 am ]
i dont even have a choke cable hooked up to mine and have only had to choke it once when it was 20dg outside. Starts everytime without a problem. I can tell you if you ahve a air leak in you gas line it will loos prime and not start. If you notice you prime not holing after you kill the motor for a few hours then check you line you have a leak.
Author:  bbb [ Thu Jul 01, 2010 7:05 pm ]
