Valve adjustment question http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=10664 |
Author: | SmokeEater829 [ Sun Jul 04, 2010 7:01 pm ] |
Post subject: | Valve adjustment question |
I've got a 35 GDSD with about 200 hours on her. To my knowledge, the valves have never need adjusted. I'm trying go find out if the 35 vanguard had adjustable valves or do I need shims to adjust them? I've noticed that lately it's been a little harder to start my motor and a little bit of black smoke out of the exhaust when I do start it up. It usually gets worse once the motor is hot after running for a while. Am I correct in thinking that a valve adjustment would help use issues? |
Author: | quackconsumer [ Sun Jul 04, 2010 7:20 pm ] |
Post subject: | Re: Valve adjustment question |
Pull your valve covers off and set dem at 0.005 while at a 1/4" past top dead center. |
Author: | SmokeEater829 [ Sun Jul 04, 2010 8:52 pm ] |
Thanks. I'll probably get that done this week. |
Author: | OwenDickeson [ Sun Jul 04, 2010 9:02 pm ] |
Its real easy to do...just go get you a feeler gauge and set em to .005 |
Author: | shallow water master [ Sun Jul 04, 2010 9:16 pm ] |
Author: | SmokeEater829 [ Sun Jul 04, 2010 9:34 pm ] |
Chris and I are gonna do it one day this week. |
Author: | shallow water master [ Mon Jul 05, 2010 3:18 am ] |
ya thought so but do me a fav and see if he would do mine for me to |
Author: | Mitschke [ Mon Jul 05, 2010 2:29 pm ] |
When exhaust is open... Set intake When Intake is open... Set exhaust Repeat for the second hole |
Author: | bjg [ Mon Jul 05, 2010 4:44 pm ] |
You guys are so smart. I wish I could be like yall. Your all my idols. |
Author: | Pooh Bear [ Mon Jul 05, 2010 5:14 pm ] |
compression stroke................ |
Author: | SmokeEater829 [ Mon Jul 05, 2010 6:11 pm ] |
Well, adjusted my valves this afternoon. Really easy job. But I did find a new problem while doing so. Went ahead and checked compression and I'm WAY low on each cylinder. 82 on one side, 86 on the other. I really could have done without this. Oh well, time to start looking for parts. |
Author: | bjg [ Mon Jul 05, 2010 7:08 pm ] |
Author: | SmokeEater829 [ Mon Jul 05, 2010 7:46 pm ] |
No, didn't open the throttle. Guess I'll have to check it again. |
Author: | bayouboy [ Mon Jul 05, 2010 8:16 pm ] |
Author: | Pooh Bear [ Mon Jul 05, 2010 8:17 pm ] |
Author: | bjg [ Mon Jul 05, 2010 8:24 pm ] |
Author: | bayouboy [ Mon Jul 05, 2010 8:25 pm ] |
Without the throttle open the intake is basicly a closed valve cutting off your air supply. No air means your not going to get the air needed to displace / fill the cylinder, causing the piston to draw some what of a vaccum until it can compress what air that it had or what it could actually suck in. Is that right BJG? ![]() |
Author: | bjg [ Mon Jul 05, 2010 8:28 pm ] |
Author: | bjg [ Mon Jul 05, 2010 8:31 pm ] |
either that or u set the valves to loose. But i dont think thats the case. They would have to be really loose. |
Author: | Pooh Bear [ Mon Jul 05, 2010 9:20 pm ] |
one day I"m gonna grow up big just like you smart fellas.......You guy's rule .....lol thanks for the explanation. Learned something new everyday. |
