Water Fuel Seperator(Primer Bulb before or after the filter)
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=11122
Author:  canvasbackdrake [ Fri Jul 23, 2010 8:58 pm ]
Post subject:  Water Fuel Seperator(Primer Bulb before or after the filter)
Hey guys I have seen several pics with the primer bulb after the filter, and several before the filter. What does anyone suggest for better performance or does it matter? Thanks for the info :D .
Author:  POKER1 [ Fri Jul 23, 2010 9:34 pm ]
Post subject:  Re: Water Fuel Seperator(Primer Bulb before or after the fil
Whatever floats your boat. I like mine down on the floor so if my fuel pump ever goes out I can pump it with my foot and keep going. Plus as these bulbs get older they probably could come apart so Id put it before the filter.
Author:  gaboy [ Sat Jul 24, 2010 10:50 am ]
after the seperater and before the fuel filter
Author:  Pooh Bear [ Sat Jul 24, 2010 11:12 am ]
Author:  JIMMY W [ Sat Jul 24, 2010 2:20 pm ]
Put it between your tank and water seperator!!If you run out of gas you will be able to prime your filter! ;)
Author:  OwenDickeson [ Sat Jul 24, 2010 2:40 pm ]
Author:  radikkle [ Sun Jul 25, 2010 7:09 pm ]
Author:  Over the LINE [ Sun Jul 25, 2010 8:02 pm ]
Changed my seperator, primer bulb and the line to the engine filter yesterday. My bulb is after the seperator and it primed just fine even with all that stuff bone dry.
Author:  deadbird8 [ Tue Jul 27, 2010 5:36 am ]
