It is currently Fri Jan 30, 2026 8:46 am
[ 9 posts ] |
EVT carb & intake kit vs MB carb kit
DC
Joined: Wed Jan 21, 2009 9:50 pm Posts: 124 Location: Lakeville, MN
Looking to add an exhaust and carb kit to a 35MB. Anyone have any opinions on EVT setup verses MB's? Do you really see any performance gains without having head work by using EVT's intake?
| Sat Mar 14, 2009 1:56 pm |
deadbird8
 Re: EVT carb & intake kit vs MB carb kit
| Mon Mar 16, 2009 7:10 am |
mudd
Joined: Wed Jan 14, 2009 5:44 pm Posts: 443 Location: Wisconsin
You will see and honest 1-2 mph gain from Carb/Exhaust upgrade. It will have better performance all around from idle to top end.
_________________ THE, FIRST and ONLY MMT Member of the Year!
| Tue Mar 17, 2009 7:31 am |
DC
Thanks for the reply. I'm planning sold on purchasing a kit just not sure which one, EVT's or MB's. Biggest difference between the carb kits is the intake which appears to be less restrictive with EVT. Without have head work was curious if anyone had an opinion on EVT's intake compared to the adapter MB provides?
| Tue Mar 17, 2009 8:07 am |
50fps
I like the EVT intake, and the BPS throttle cable setup is well designed. Both use a rubber flange to mount the carb, one directly to the manifold and the other to a manifold adapter. Now if Mike or Robert would turn the flange 90 degrees on their intake and have the same bolt pattern as a S&S Super G, I'd buy one just so I could run a PSI Big Air or S&S carb.
| Tue Mar 17, 2009 8:27 am |
drake1
Getting ready to run a S&S E on one. Built an adapter to fit my intake. If we like we may switch.
| Tue Mar 17, 2009 9:34 am |
50fps
| Tue Mar 17, 2009 2:51 pm |
deadbird8
| Wed Mar 18, 2009 6:12 am |
50fps
| Wed Mar 18, 2009 7:22 am |
[ 9 posts ] |
