It is currently Sat Jun 28, 2025 10:01 pm
Reply to topic  [ 6 posts ]
 exhaust gasket
Post exhaust gasket
I picked up a sheet of gasket for 10 bucks at the auto store yall think I should double it up? Has anyone ever used this stuff before? It's no big deal to cut it out but cutting the inside holes is giving me a little grief. I was about to get the dremel out but it has run away with my box cutter.
"You may all go to hell, as for me I'm going to Texas" D. Crockett
What is best in life?
To crush your enemies, to see them driven before you, and to hear the lamentations of their women.
Tue Aug 17, 2010 10:33 am
Post Re: exhaust gasket
A Xacto knife would work pretty good.
Copperhead 12Hp SD on 1442 Alweld
Tue Aug 17, 2010 10:37 am
I seen an episode of Horsepower TV and they showed how to make your own gaskets. Use some old pistol or rifle shell casings to stamp out your holes in gasket material. it works well when you punch them out with a hammer.
9MM = .354"
.38 = 3/8"
.45 = 7/16"
.50 cal = 1/2"
Tue Aug 17, 2010 10:38 am
the gasket has the metal backing, I found my dremel the first one looks like sh*t.
Tue Aug 17, 2010 10:54 am
There you will have a problem.What about a hole saw that you put on a drill. Use light pressure. Maybe a metal one.
Tue Aug 17, 2010 12:14 pm
Tue Aug 17, 2010 12:32 pm
Users browsing this forum: No registered users and 107 guests
