PD electrical problem?
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=11288
Author:  50fps [ Sun Aug 01, 2010 1:41 pm ]
Post subject:  PD electrical problem?
Here is the situation, while heading out to go catch some gills on poppers, I lost power to the clutch.
I then tried to shut down the motor with the key switch with no results.
Then I pulled the safety kill and once again no results.
So then I pulled the plug wires and ding ding it killed ;)
I then turned the ignition switch back on (without starting motor)and engaged the clutch and ta da it engaged.
So then I tried the momentary and it worked also.
Now mind you this is with the engine not running, but key switch turned on and the safety lanyard pulled.
I then hook up safety lanyard and guess what? The clutch function is now not working.
So I assume it's the safety kill and bypass it.
I then start the motor and engage the clutch and it kills the spark.
So basically with the safety switch eliminated, I can run the motor, but not kill it with the key switch and if I do engage the clutch it kills the ignition.
I then put the trolling motor down and take a nice leisurely cruise back to the launch.
I am assuming the ignition switch is bad.
Has anyone else had a similar problem and what was the cure?
Any info would be helpful.
Author:  Joe M [ Mon Aug 16, 2010 2:50 pm ]
Post subject:  Re: PD electrical problem?
Yes, I had the exact same symptoms. It was a short at the clutch. It ended up melting my wiring harness.
Author:  50fps [ Mon Aug 16, 2010 6:32 pm ]
Found the problem. It was in the flat connector of the main harness, on of the terminals had corroded and wasn't fully seated.
Author:  Joe M [ Mon Aug 16, 2010 6:40 pm ]
wish that was what happened to mine
Author:  dylndaw [ Mon Aug 16, 2010 6:44 pm ]
Author:  Joe M [ Mon Aug 16, 2010 7:00 pm ]
Short at the clutch, my wiring harness fried.
