how much and with what? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=11608 |
Author: | benny365 [ Thu Aug 12, 2010 9:27 pm ] |
Post subject: | how much and with what? |
How much are valves shimmed and with what, is there something to buy or do you make your own. I have a 35 gdsd and I wouldn't mind a little valve float protection. thanks |
Author: | MaXXis85 [ Fri Aug 13, 2010 6:35 am ] |
Post subject: | Re: how much and with what? |
Do you have mods that allow your engine to rev 4350+ RPM with the prop engaged running in the water? If not dont bother. |
Author: | benny365 [ Fri Aug 13, 2010 6:03 pm ] |
no mods, but I do run 4200 rpms in the water, If I hit something and the prop comes out of the water. might turn more than 4350 |
Author: | cb5331 [ Fri Aug 13, 2010 6:06 pm ] |
not unless you disconnected the gov, you won't. Also, how old is your prop. Is it a cdi motor? 4200 seems a tad bit high for a stock motor and prop. |
Author: | Shadow [ Fri Aug 13, 2010 6:24 pm ] |
Author: | deadbird8 [ Fri Aug 13, 2010 6:25 pm ] |
Could be a hot motor, my old one ran 4380 with just an exhaust. Then again, he could have an e-fuel pump |
Author: | cb5331 [ Fri Aug 13, 2010 6:35 pm ] |
Author: | benny365 [ Fri Aug 13, 2010 7:23 pm ] |
Hot! not sure about that. no fuel pump either. I get about 27 to 28 mph at 4150 to 4200 rpm. I just worry about overreving it if I would hit a stump or something. motor only has 20 hrs and prop is like new. |
Author: | Shadow [ Fri Aug 13, 2010 7:24 pm ] |
Author: | cb5331 [ Fri Aug 13, 2010 7:28 pm ] |
If your running 4200 with a good prop on a stock motor, I'd say you've got yourself a hot one. Thats a good thing. Your motor has a governor on it that does not allow it to over rev. You have nothing to worry bout. Just go run that biatch. Oh, and the fuel pump thing is a joke. I don't know what crawled up ol DB8's ass, but he's having a lot of fun with it. ![]() |
Author: | benny365 [ Fri Aug 13, 2010 7:36 pm ] |
