It is currently Sun Jun 29, 2025 4:33 am
[ 6 posts ] |
Electronic Fuel Pump Question
tsutxn09
Joined: Mon Aug 09, 2010 9:36 pm Posts: 91 Location: Huntsville, Texas
The more i read on this forum the more i think i need to install a e fuel pump on my 25hp kohler gd longtail. So ive got some questions. Do i bypass the mechanical fuel pump? Do i take the primer bulb out? Do i just wire it to the ignition switch? Thanks for the help guys i need to get this sucker running ive got t minus 29 days and counting for the small duck season.
Thu Aug 12, 2010 10:26 pm |
SP
 Re: Electronic Fuel Pump Question
I installed one last year, and it made a big difference for me. The engine runs much better, and starts right up. I wired the Fuel Pump directly into my starter. Turn the key, let the Fuel Pump run for a couple of seconds and then start it up. You need to check to see if your fuel pump is a push or a pull pump. Mine is push which should be installed as close as possible to the fuel tank. I have the fuel pump installed on the bow, and then the line runs into a primer bulb, into a water seperater, into a quick connect, and into the engine. I originally took the bulb and quick connect off and ran the motor, and then put them back on, and ran the motor. There was no noticeable difference for me, so I put them both back on. The bulb is a back up in case the Fuel pump goes out, and I like having quick connect to burn the fuel out of the motor(much easier, and I do this about every time I run the engine). The only thing you could add is cut off switch to the fuel pump so you can turn it off. I hope this helps.
Thu Aug 12, 2010 10:49 pm |
deadbird8
Fri Aug 13, 2010 6:26 pm |
tsutxn09
Hey guys thanks for the help i just got a mr gasket e pump bout to go install will post some results after i get it on
Fri Aug 13, 2010 7:20 pm |
Chico80x
Joined: Tue Aug 11, 2009 10:55 am Posts: 743 Location: Ft. Lauderdale, FL
How did the install go and did it improve the way your motor runs?
_________________ "We Are Products Of Our Decisions"
Mon Sep 13, 2010 3:39 pm |
tsutxn09
still trying to work bugs out of the motor so i took the thing off ill let ya know when i get everything running
Mon Sep 13, 2010 4:05 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 112 guests |
